code 20 electrical load sensor
Old May 17, 2004 | 10:23 AM
slocrxsi's Avatar
Default code 20 electrical load sensor
hey i have an 88 crx si with stock d16a6 and i was wondering what a code 20 is. i know what it says "electrical load sensor" but where the hell is that and how can i fix it.
also just to make sure it is a 20. it blinks solid once and then 20 times fast. i havent really had a CEL on this car my old car was obd-1 and a solid meant 10 but on pre obd i thought the solid is a splitter blink. if im wrong someone please let me know.
but if anyone knows how to fix this please help me because the CEL sounds like it could be pretty bad.
Old May 17, 2004 | 11:18 AM
civickiller's Avatar
Default Re: code 20 electrical load sensor (slocrxsi)
do a search you can probably find an answer
Old May 17, 2004 | 11:37 AM
EL Vap133's Avatar
That doesn't sound like a code 20, but it also doesn't sound like a normal code.
Old May 17, 2004 | 11:54 AM
91' Z-6 Canadian hatch's Avatar
I have the same code in my si hatch code 20 electrical overload been driving with the code for about 2 years and hasn't changed, when you find out what was causing let me know curious what the problem is. other than that not to worried about it. The computer will flash once when you first key-up but anything after is a code.
Old May 17, 2004 | 11:58 AM
wickedEFguy's Avatar
Default Re: code 20 electrical load sensor (91' Z-6 Canadian hatch)
If you don't know what a ELD is this will probably help you out
http://www.binghamtonlife.com/...1.jpg
LoseRPunKx182
Aug 4, 2005 01:50 AM
93b18civic
Mar 21, 2004 06:48 PM
EK_vzla
Oct 8, 2003 11:20 AM
Damon B.
Jan 19, 2002 02:46 PM
