air intake for B16A or CRX???????
Old May 17, 2004 | 07:50 AM
91crxSIb16a1's Avatar
Default air intake for B16A or CRX???????
I have a 91 crx si with a B16A1 swap, and want to buy an aftermarket air intake. DO I buy an intake for the car (crx) or the engine?
Old May 17, 2004 | 08:00 AM
hahahahhah's Avatar
Default Re: air intake for B16A or CRX??????? (91crxSIb16a1)
I would imagine that you would have to buy an intake for a VTEC Del-sol (B16A1) due to the throttle body size difference (55mm on the stock CRX engine, 58mm on the B16A1).
Correct me if I am worng, I'm only going on assumption.
-edmCRX
Old May 17, 2004 | 08:02 AM
Mr_CRX's Avatar
Default Re: air intake for B16A or CRX??????? (edmCRX)
the 99-00 Si intakes fit if you relocate your battery. the crx one isnt going to be designed for a b16. Or, you can get one of the new AEM hybrid intakes. I'm not sure when they come out though.
Old May 17, 2004 | 08:08 AM
crx_88_si's Avatar
aem intakes for hybrids - $$$$$$ get a delsol vtec and relocate battery.
Old May 17, 2004 | 08:17 AM
RobbieG35's Avatar
12 Years Strong
Default Re: (crx_88_si)
I would get a Del-Sol VTEC, 99-00 Civic Si short ram or cold air work fine, or you can get an AEM CAI for the Type R to work (3" piping)
Old May 17, 2004 | 08:21 AM
hahahahhah's Avatar
Default Re: (HybridHatch88)
yea sorry, forgot to mention you gotta relocate the battery.
something I gotta do today
Old May 17, 2004 | 08:43 AM
1QWKCRX's Avatar
Default Re: (edmCRX)
Yeah I was wondering the same thing.
But I have seen people with intakes and battery in the
stock location.
So which intake will work with a stock battery location?
Old May 17, 2004 | 08:47 AM
hahahahhah's Avatar
Default Re: (1QWKCRX)
Something that isn't bought in a store, that's for sure .
Old May 17, 2004 | 09:19 AM
Mr_CRX's Avatar
the reason people get a different intake and relocate the battery is because they want an intake pipe diameter that is matched for the engine. A stock crx intake, or aftermarket for that matter, will work with the battery in the stock location. However, these are usually 2.5" pipes which are designed for a 1.6 liter, 108 hp engine. It'll work with your b16, you will probably just be losing a little power. I cant really say how much, cause I dont know.
I'll be using an Injen CAI for a crx with my b18c because it came with my swap and I'm too cheap to buy anything else right now.
ironchef25
17
Apr 11, 2004 03:35 PM
88crx Osaka
Dec 9, 2003 02:22 PM
jaydm98
17
Jun 4, 2003 09:38 PM
b16powwer
May 13, 2003 06:36 AM
turbohf
23
Feb 18, 2003 12:24 AM
