Is y21 a tranny that exist on USDM. Want to order axles, LS 5th and a quife etc.
I posted this in the FI forum but there is not much of a response. i know the knolege is high here too so there for I´m trying here aswell..
I have an engine and tranny from a european del-sol vti from 92 that come stock with b16a2 and a y21 tranny with a hydralic clutch.. Does the y21 tranny exist on the USDM? Or is there any simular ones?
I don´t remember for sure but when I met Ron Burgenholtz at Golden Eagel I think he said that I should order a LS 5th from -94 and up. Can anyone confirme this so I don´t order the wrong one.
I also need a Quife LSD.. That should be the same as for the usdm b16 tranny as far as I know.. But need to know for sure.. Anyone?
I think the b16 del-sol in US has a b16a3.. I thought that it was an y21 tranny in that one.. Anybody knows for sure?
I kneed to get some info so I can order some Gator stage 3 axles...
I´m thankful for any help...
Yes the Y21 is the USDM Del Sol DOHC VTEC transmission. Pending that it is stock with no factory LSD, the Quaife 99-00 civic Si will fit and the model number is:QDF1U1. In USDM form the 99-00 civic Si has the same gear ratio as the Del Sol in DOHC versions. The parts are interchangeable. Hopefully that will help you out a bit
Yes it will... Thanks alot..
Anybody knows about LS 5th for the y21 tranny?
The sweed
May 17, 2004 02:09 PM
