2004 Honda Civic WIring Diagram
Old May 17, 2004 | 06:21 AM
BEN52's Avatar
Default 2004 Honda Civic WIring Diagram
Can anybody hook me up with a wiring diagram with wire colors for a 2004 honda civic vp. I need to know the colors of the rear left and right speakers.
Thanks,
Ben
Old May 17, 2004 | 07:45 AM
B18C_EJ8's Avatar
You could just use a wiring harness adapter and have been done by now... Unless you're one of the really smart guys that cuts the plug off the factory harness.... Just pop test the wires with a battery, or bette yet, maybe try the "search" function....
Old May 17, 2004 | 08:20 AM
BEN52's Avatar
hey **** face, i already searched, and nothing came up. second of all im not installing a headunit, *** hole.
Old May 17, 2004 | 08:28 AM
proglife's Avatar
DAMN! This place is gansta!
Old May 17, 2004 | 06:21 PM
B18C_EJ8's Avatar
Couldn't you just look at the wires coming off the rear left and right speakers?
Old May 18, 2004 | 04:31 AM
TurboBumblBee's Avatar
Default Re: (BEN52)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BEN52 &raquo;</TD></TR><TR><TD CLASS="quote">hey **** face, i already searched, and nothing came up. second of all im not installing a headunit, *** hole.</TD></TR></TABLE>
calm down.. no need for name calling.. if your not installing a headunit, what do you need the colors for??? well i was the nice guy and looked them up on DEI's website.. here you go no go along and play nice with everyone
Radio 12v white/red + radio harness
Radio Ground black - radio harness
Radio Ignition yellow/red + radio harness
Radio Illumination red/black + radio harness
Factory Amp Turn-on
Power Antenna
LF Speaker +/- grn/blk - lt. green radio harness
RF Speaker +/- grn/yel - gry/red radio harness
LR Speaker +/- blu/wht - blu/blk radio harness
RR Speaker +/- pink - blu/yel radio harness
Old May 19, 2004 | 06:05 AM
BEN52's Avatar
Im using them to tap for a line level converter.
Old May 19, 2004 | 07:25 AM
hoggy's Avatar
Actually you really have no need for the wire colors then. Tou should just be able to match up by looking at the plugs and make sure and use the same location on each plug for positive on the line level as well as the same pin for negative to the line level.
coa132435
Jul 5, 2019 11:35 AM
pityocamptes
10
Dec 20, 2013 05:42 PM
unclejemima
Sep 13, 2004 01:10 PM
hagrid
Audio / Security / Video
Dec 4, 2002 09:05 PM
