Need Help on wiring OEM Fog Light Switch
I did a couple of searches on trying to find out how to wiring this OEM fog light switch but couldn't find any that could help me. I bought this switch bare with no connector and I need to find out which pin is the ground, Power, positive and negative, etc. Any help will be appreciated thx ppl
What car are you putting this in? 90-93 teg? That doesnt even look like the switch in my teg. Ill take a picture of the harness tomorrow if no one posts...
take another look at my writeup... https://honda-tech.com/zerothread?id=685131
the pins on your switch look exactly like the pins on mine
In a nutshell, pin1 is used as "switched input", pin3 is used as "switched output", and pin5 is "ground"
Pretty much all you need to know is in my writeup, except for the size of the female spade connectors you need to crimp to the wire to connect to the switch itself since you don't have a harness. Shoot me a PM if you can't figure it out, since you're local I might be able to help you out.
92EG8
Audio / Security / Video
Aug 29, 2007 05:59 PM
. Planned on wiring my JDM fog lights to this fog light switch
