car wont start???
Old May 16, 2004 | 08:29 PM
berettagtz117's Avatar
Default car wont start???
Ok I am still having problems w/ the car not starting?? Here is what I have and done so far..
90 Crx dx w/ d15B2 bottom end, Y8 head, Y8 mani/fuel rail and obd2 injectors and clips Pr4 ecu. I wired up MPFI, and SI dizzy, I am getting spark and plenty of fuel, I have the crank at TDC on white mark and head cam at Up position on timing, The car just turns over but does not want to start, Ihad it running a couple of times but just died and that was it. I pull out the plugs and they have a charcoal black substance on them and just loaded with fuel. I am throwing a code 4 Crank angle. I tried switching out dizzys with my buddys running Si but still changed nothing? I triple checked all the wiring, lines ect... I took off the head again tonight to check everything out and everything looks fine. I am running 180 compression on all 4. I am totally lost and dont know what to do now.. Somebody please help!!
Old May 17, 2004 | 02:03 AM
civickiller's Avatar
Default Re: car wont start??? (berettagtz117)
did you do a compression test ?
Old May 17, 2004 | 08:11 AM
LSVTEC 91 Civic's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by berettagtz117 &raquo;</TD></TR><TR><TD CLASS="quote">I am running 180 compression on all 4. </TD></TR></TABLE>
Old May 17, 2004 | 11:23 AM
Default Re: car wont start??? (LSVTEC 91 Civic)
opps
if you got fuel and you got spark and compression theres no reason why it shouldnt start, other then the spark or the fuel is off. like its sparking or sending fule at the wrong time. try check and make sure you dont have wires or injector wiring switched
Modified by civickiller at 9:06 PM 5/17/2004
Old May 17, 2004 | 11:34 AM
wickedEFguy's Avatar
Default Re: car wont start??? (civickiller)
check your Dizzy wiring and see that everything lines up, use a voltmeter to check for shorts to
Old May 17, 2004 | 04:13 PM
I keep switching the injector plugs around to make sure they are not off. But just to make sure How exactly does it go?? A1 from ecu which is injector one does it go to #4 cylinder closest to dizzy or #1 cylinder closest to cam gear?? and the rest just follow after that one.. Thanks, KYle
88CiviHatch
May 5, 2010 03:33 PM
Rease3
15
Mar 3, 2008 07:32 PM
Iron_Forrix
May 22, 2007 12:33 AM
menappi
19
Jul 27, 2005 09:57 PM
shauniewalnuts
Jun 27, 2005 08:20 PM
