Has anyone ever done a dohc swap on a crx dx
Old May 16, 2004 | 08:18 PM
Dirttylicous's Avatar
Default Has anyone ever done a dohc swap on a crx dx
i have searched and even talked to people but i still keep getting different answers from people. first someone says i need to do the whole mpfi swap, but another said i only need the wiring harness for it. also one said i will need a new tranny and ecu from the zc motor and another said my stock ones are fine. can someone please clear this up for me or email me at dirtyylicous@aol.com or im me dirtyylicous. thanks alot
Old May 16, 2004 | 08:20 PM
0554's Avatar
nope nobody has ever done it in the dx only the si and hf models LOL
Old May 16, 2004 | 08:22 PM
i didnt mean it like that i was just asking for help from people that have done it
Creepshow S60's Avatar
Default Re: (88crex)
dohc zcs cannot be swapped into a crx.
-cody
Old May 16, 2004 | 08:28 PM
i was told they can be, and all im trying to do is ask for help, i searched and didnt find anything helpful
Old May 16, 2004 | 08:46 PM
1point5CRX's Avatar
Default Re: (Dirttylicous)
my car is a 91 dx, i already swapped a zc into it, you need to covert your wiring to mpfi, get the ecu (pm6=si) or if you swap in a ls, get the ls ecu with it, you can swap another d-series in without mounts but a b-series will require it along with a shift linkage and a few other things.
go to d-series.org for alot more info also
Old May 16, 2004 | 08:56 PM
manson's Avatar
Default Re: (1point5CRX)
you should go here...
https://honda-tech.com/zerothread?id=749544
» Search Results
Your search for dohc returned 245 results.
always search the archives...
please read the FAQ at the top of the page...
we :honda-tech: have covered this matter hundreds of times. you may have been looking for help, but if you actually searched or learned how to search or read the FAQ you may have had a chance to actually find what you were looking for.
now all we have is a pointless post. right on!
Old May 17, 2004 | 05:14 AM
kyle h.'s Avatar
Default Re: Has anyone ever done a dohc swap on a crx dx (Dirttylicous)
why would you want to do that? they come with dohc's, people always swap them out for sohc's
Old May 17, 2004 | 05:50 AM
crx_88_si's Avatar
you can use your stock tranny (although it's not the most performance oriented gearing). you will have to do a MPFI wiring swap. + ZC wiring changes (move a few wires). use a 88-89 teg pg7 ecu or a 88-91 pm6.
thompbird
Jul 3, 2007 05:16 PM
extreme90civic
Sep 4, 2005 11:30 PM
1115R
Jul 19, 2004 03:35 PM
jdmhondacrx
Mar 16, 2003 11:28 PM
dropd4door
Jan 25, 2003 09:38 PM
