Cam questions.
Old May 16, 2004 | 06:31 PM
Chigga1's Avatar
Default Cam questions.
hey guys im sporting the B16A2
just before i do my timing belt change, im going to change my cams.
either ITR or CTR, havent decided yet, also, shouuld i buy CAM GEARS???? would this help in properly tunning these? or should i just run Stock Cams and run them at 0 degree and not change the timing????
now when installing my ITR instake springs and moving my Intake springs from my SIR ( SI to U.S ) to the exhaust side... now just out of curiousity.
Since Honda's are backwards in a way.
the INTAKE Cam would go on tha side with the INTAKE MANIFOLD right???
and the Exhaust towrds the Header????
am i right???
im a bit confused so before doing so..
what would u guys recommend...?? ITR or CTR?
how r the gains??
i got I/H/E, pullies
thanks.
Old May 16, 2004 | 06:52 PM
Dan GSR's Avatar
Default Re: Cam questions. (Chigga1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chigga1 &raquo;</TD></TR><TR><TD CLASS="quote">
and the Exhaust towrds the Header????</TD></TR></TABLE>
yes
if you tried to install it the other way, it wouldn't work, as the notch for the distributor is only on the intake cam
redDAinteg
Apr 25, 2007 09:10 AM
b00sted4dr
15
Oct 28, 2004 08:42 AM
tilt
Mar 19, 2003 06:55 PM
trustbuddy
Feb 8, 2003 01:03 AM
MRDC2
Jul 4, 2001 03:02 PM
