Seat belts/4pt Harness Buzzer
Old May 16, 2004 | 06:12 PM
rhetorical's Avatar
Default Seat belts/4pt Harness Buzzer
Hey I took off my door panel today so that I could pull out the seat belt (dead weight) because I'm going with 4pt harnesses. Unfortunately, I found that there are electrical connections to the seat belt things. If I disconnect these permenantly will anything happen? ie-a buzzer, a warning light, etc.
any help greatly appreciated, thanks
Old May 16, 2004 | 06:17 PM
MooreBoost's Avatar
Default Re: Seat belts/4pt Harness Buzzer (rhetorical)
I never reconnected mine when I took out the seat, and it doesnt do anything. You should be fine.
Old May 16, 2004 | 06:25 PM
rhetorical's Avatar
So did you take off the door mounted seat belt?
Old May 16, 2004 | 06:29 PM
MooreBoost's Avatar
Default Re: (rhetorical)
I unhooked the wire that ran to the buckle under the seat. Im not sure about the one in the door panel but I cannot see why one would set off the buzzer but not the other.
Old May 16, 2004 | 06:43 PM
xci_ed6's Avatar
Default Re: (tegunderpressure)
my idea, disconect, if you get a buzzer, short them together, but I think they are inline w/ the seatbelt one, so leaving them unhooked should be fine.
Old May 16, 2004 | 06:51 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (krustindumm)
You have to keep the plastic caps with the electrical connectors in the door panel, take out the seat belts, but those plastic caps have to stay. I had to do this to stop the buzzing.
Old May 16, 2004 | 06:57 PM
rhetorical's Avatar
Allright thanks yall, the only problem is my battery's out, otherwise i'd be able to check it. I'm just waiting till about the end of the summer to get the new battery, thats when its gonna run. No use in getting it rearly I'll let yall know in bout 3 months if it works or not
.Noah Fecks
10
Jun 19, 2003 08:43 AM
.Noah Fecks
Jun 9, 2003 10:13 AM
crashtest Sonny
23
Jun 3, 2003 12:30 PM
