crv 5 lug conversion
Old May 16, 2004 | 05:37 PM
civictyper99's Avatar
Default crv 5 lug conversion
I heard from a guy that a crv 5 lug conversion will work just like a type r 5 lug cnversion. Does anyone know anything about this. Are there a modifications that need to be made.
Old May 16, 2004 | 11:05 PM
evosol's Avatar
Default Re: crv 5 lug conversion (civictyper99)
bump this biatch because i want to know too!
Old May 17, 2004 | 08:34 AM
Rod.'s Avatar
Default Re: crv 5 lug conversion (evosol)
intresting, I would also like to know
Old May 17, 2004 | 03:15 PM
bump
Old May 17, 2004 | 03:27 PM
Katman's Avatar
I could be wrong, but I'm not fully sure if this conversion is possible to make work on a civic, because the rear trailing arms are designed a little different to accomodate rear axles for the Real-time 4WD system.
As for the fronts, I'm not sure if the geometry/design of the the front knuckle's are exactly the same as regular EK civic knuckles; they may be designed a little differently to accomadate the raised stance a CRV has -- although that could all just rely on the spring & shock, and the knuckle assembly could indeed be exactly like an EK civic's knuckle assembly. Something I'm not sure about.
but i know of for a fact that the front wheel hubs & brakes are exactly the same as 5-lug ITR hubs & brakes...but ...CRV's use a bigger axle spline & nut (36mm). The rear hubs & brake size I'm not sure about though.
sorry for the half-*** info..haha..
Old May 20, 2004 | 04:38 AM
bump
Old Aug 19, 2006 | 10:05 AM
Krucial_Ek9's Avatar
your ek from fivestartuning? bump for a fellow ATL/EK owner, i would also like to know.
Old Aug 22, 2006 | 11:35 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: crv 5 lug conversion (Krucial_Ek9)
according to katman, you would really just need the front and rear hubs, jdm axles, rear spindles, and the appropriate calipers for the front and rear. if you can pull these parts yourself, or get a good deal, then start pulling and start piecing.
TheBeardedMamba
14
Apr 7, 2017 02:07 PM
russianswty
Sep 26, 2007 04:59 PM
jimmhatch
May 22, 2005 11:07 PM
mrdanglez
Apr 12, 2004 11:47 PM
1337 Si
Nov 15, 2003 12:00 PM
