just a new headlight idea for integra projector i though of
Old May 16, 2004 | 05:33 PM
tekstyle's Avatar
Default just a new headlight idea for integra projector i though of
u guys might think this is a silly stupid ingenius idea, but for those that are disassembling their headlights, please give it a try anyways. it will all take about 5 mins . ( i didnt want to do this myself becuase i already openned it up 3 times and have no reason to )
after u disassemble it. remove the lens and use masking tape to tape the bottom half of the backside of the lens.
then put it back onto the projector and test out the cut off. i m not sure, but it might make the cut off more defined than usual.
NOTE: if this does miraculous work for u, please use sumthing like a metal plate instead for it is hot inside the chamber. and please provide testimonials if u do, do this . thanks
i thought of this because the light blocker inside the integra projector is conture with the middle furthest away from the lens. this will cause enough diffusion for the light to pass through the bottom half of the lens causing the light to be bent upward resulting in glare. covering that up might help prevent diffused light from pass through the bottom.
Old May 16, 2004 | 08:34 PM
tekstyle's Avatar
Default Re: just a new headlight idea for integra projector i though of (tekstyle)
any body?
Old May 16, 2004 | 08:40 PM
m R g S r's Avatar
I don't know if anyone is willing to do that, well maybe patrickgsr94 will, he is always messing with the headlights.
thumper64
Jan 23, 2010 09:11 PM
lance_a_123
Aug 13, 2008 03:22 PM
ooopseyesharted
Nov 25, 2007 07:36 PM
Ri5e
Nov 28, 2003 10:58 AM
