What camber kit are you 5th gen guys using?
Old May 16, 2004 | 04:29 PM
SlammedCD7's Avatar
Default What camber kit are you 5th gen guys using?
Old May 16, 2004 | 07:19 PM
whoa its len 2's Avatar
Default Re: What camber kit are you 5th gen guys using? (Wylie15)
None up front. Washers in the rear.
Old May 16, 2004 | 07:22 PM
iam7head's Avatar
Default Re: What camber kit are you 5th gen guys using? (whoaitslen2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whoaitslen2 &raquo;</TD></TR><TR><TD CLASS="quote">None up front. Washers in the rear. </TD></TR></TABLE>
HDm style huh? Home depot racing..
you can fix the rear with a longer bolt and a bunch of washers.
sucks for the 6th gen gen
Old May 16, 2004 | 07:38 PM
SlammedCD7's Avatar
Default Re: What camber kit are you 5th gen guys using? (iam7head)
well i planning on washer **** on the rear but idk how much correction you can get with it. im going to drop my car 1.5 untill i get a kit then 2.5-3 with the kit, so is Ingalls a good company and which is the best type of kit? **** had another question but forgot, damn the life of a stoner
Old May 17, 2004 | 03:56 AM
AccVic's Avatar
i'm using an ingalls kit for the front with no problems
Old May 17, 2004 | 07:58 AM
JDM.Accord's Avatar
You can have it on the ground and get enough correction with the Ingalls kit. I had mine dropped 3" (before I got a body kit and 18's) and the kit worked great for me with just washers in the back. I can't image lowering a 5th gen much more then that and still driving it on a regular basis.
Old May 17, 2004 | 08:39 AM
accordhybrid's Avatar
ingalls up front
Old May 17, 2004 | 08:58 AM
fw190bvi's Avatar
Default Re: (accordhybrid)
soon to be: no camber corrections w/ agx's and sportlines......UPS is coming today......6 months of waiting is over!!!!!!
Old May 17, 2004 | 09:25 AM
.bagged's Avatar
Default Re: (fw190bvi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi &raquo;</TD></TR><TR><TD CLASS="quote">soon to be: no camber corrections w/ agx's and sportlines......UPS is coming today......6 months of waiting is over!!!!!!</TD></TR></TABLE>
congratulations..
Old May 20, 2004 | 10:27 PM
94excoupeaccord's Avatar
Default Re: (bagged93accord)
Just got my suspension done today!yaaaaaaaaaaaaaaaaaaay Gotz ground control coilovers, kyb gr-2, and for the camber I went with adjustable ball joints in front and ingalls in rear. Get to pick up in morning
Old May 20, 2004 | 11:08 PM
jjj784's Avatar
i have spc anchor bolts up front and washers in rear
Old May 21, 2004 | 02:23 AM
s.cali alan's Avatar
none in the front, ingalls in the rear. all -1 around.
Old May 21, 2004 | 07:40 AM
Hondaaccordvtec's Avatar
Default Re: (s.cali alan)
I'm using progress' kit front and rear. The front pushes the upper a-arms out to correct camber. Had to do a little "shaving" to get enough clearance from hitting the inside fender well.
I've had them for over 3 yrs - no problems to this day.
Old May 21, 2004 | 07:51 AM
biggs2.3's Avatar
i think camber kits are garbage. you car will handle better with some camber in the front. true your tires will wear faster, but that is just the price you pay. i had an ingalls camber kit on my 95 accord and it kicked the upper controll arms out to far and they were hitting the top of the wheel well and blew out the ball joints. so now i don't have one on there and i have tyhe car slamed on some apexi wsd and my camber is only off alittle bit, not bad
Old May 21, 2004 | 10:13 AM
swoosher21's Avatar
i used the Eibach alignment kit up front. very solid setup.
Old May 24, 2004 | 05:10 PM
psilo's Avatar
Default Re: (swoosher21)
Swoosher, can you please tell me more about this kit?
Did you install it yourself?? Is it easy?
And also, is it the style of kit that messes around wtih castor too and is hard to set?
Plz lemme know, much appreciated
Old May 24, 2004 | 05:51 PM
HAccord96's Avatar
Default Re: (psilo)
Ingall's kit for the front and 4 washers per each bolt for the back. -1 degree for all four sides.
Old May 24, 2004 | 10:12 PM
mikeyvt's Avatar
Default Re: (94excoupeaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94excoupeaccord &raquo;</TD></TR><TR><TD CLASS="quote">Gotz ground control coilovers, kyb gr-2, and for the camber I went with adjustable ball joints in front and ingalls in rear. </TD></TR></TABLE>
How low are you planning to drop it? Hope you know that the gr-2s are stock replacments.
fafsa
Apr 6, 2005 03:42 PM
1hellakutevietboi
Oct 30, 2004 07:26 AM
knightlude
Apr 5, 2003 08:54 AM
vpforeva
Jun 7, 2001 09:04 AM
