checking o2 sensors
Old May 16, 2004 | 01:14 PM
Shorty C's Avatar
Default checking o2 sensors
can you tell if an o2 sensor is bad just by looking at it? Im constantly throwing code 45 and im thinking the sensor in my header went bad.
Old May 17, 2004 | 09:13 AM
EE_Chris's Avatar
Default Re: checking o2 sensors (Shorty C)
No.
How many miles are on this O2? If you were running rich for a length of time (like an untuned basemap), you can foul out the O2 sensor. Burned coolant and oil will also conataminate an O2. O2's are serviceable items anyway, they do have a finite life span. On my stock 99 hatch, I typically see a decrease in performance/gas mileage at around the 60-70k mile mark....and this is a stock Y7 ECU that always leaves the spark plugs a white'ish/tan'ish color when I change them at the 15k mark (point is, its never seems to run rich).
Old May 17, 2004 | 09:28 PM
Shorty C's Avatar
Default Re: checking o2 sensors (EE_Chris)
99 si has about 99k on it now
when i changed the cat, the sensor looked a bit on the black side. I havent checked the one on the header recently.
cwf1988
May 26, 2008 12:58 PM
odishaw
Feb 16, 2008 08:34 AM
rebuiltSI
Jul 24, 2007 04:50 PM
honda89
Sep 28, 2004 08:19 PM
boost fed ls
Aug 31, 2004 07:45 PM
