Confused about tranny.
Ok, here it goes. I just had a Quaife LSD installed in my first gen B16 S1 tranny. I installed a Exedy stage one (same clutch I had before on same tranny) and when I was puttin the clutch cable on it was very hard. Like the cable was way to short for the clutch lever. Well, with the wheels off the ground it will go in gear with the clutch pressed on the floor and with it completly out. BUT, when I have clutch pedal depressed half way down then the wheels dont move (while motor running) and it goes in gear a lot smoother. When the car is on the ground it will not go in gear. When on the ground and whith the pedal all the way down tryin to push it in gear the car wants to move slightly. Havnt tried it puttin it in gear on the ground with the pedal halfway down yet.
Try to sum it up, Im confused about it so its hard for me to explain.
Off gorund: Goes in gear with pedal all the way down
Goes in gear with pedal all the way out also but still doesnt feel good.
With the pedal half way down, goes in gear smooth and wheels stop moving.
On ground: Doesnt want to go in gear and tries to roll forward with the clutch all the way down.
Sorry if this is long and confusing, but I tried to explain it the best I could and I have no clue about this. Thanks.
Matt
Matt
Random guy
Dec 3, 2006 10:33 AM
loudsubz
May 9, 2004 03:12 PM
