Help with stagnant lude
So i'm helping a friend out with her 95 lude vtec and here is the deal
The car has been sitting for about 2 years now....no precautions were taken to prepair the car for this
I've got a pretty good list of things i'm going to need and I wanted any additional help you guys have to offer
I'm going to change the oil of course do i need to pull the oil pan and clean it? I was going to change the oil again after 50 miles then again after another 50 miles
The Alternator and battery are toast (which is why it started sitting)
The gas tank is a concern that has been brought up i'm not sure how much gas is/was in it and i guess rust is a possibility so i"ll check the gas that comes out and go from there
I'm probally going to replace the belts but i'll check them first to see if it's necessary
going to flush the radiator
The tires are flat and have flatspots is it possible i don't need to replace them? or are they probally done? been flat for over a year
I was plannning on flushing the brake lines just to be on the safe side
No one seems to have an answer for power steering, clutch, and manual transmission fluids.....do i need to do anything with these or should they be ok?
I was going to put new spark plugs in are the fuel injectors ok?
Do i need to change the fuel/air filters?
umm also i was going to check the hoses/vacume lines for wear
Anything else you guys can give me would be awesome
I'm kinda concerned about rust in the cylenders which I guess is a posibility short of taking off the head is there a way i can check for this? If there is rust is there anything i can do to remove it? minimize damage to piston rings?
Thanks alot
Thanks alot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eclectic211 »</TD></TR><TR><TD CLASS="quote">
I'm going to change the oil of course do i need to pull the oil pan and clean it? I was going to change the oil again after 50 miles then again after another 50 miles</TD></TR></TABLE> good idea, i don't think you would need to pull the oil pan unless you
see some shavings or deposits in it or unless the gasket is leaking
The gas tank is a concern that has been brought up i'm not sure how much gas is/was in it and i guess rust is a possibility so i"ll check the gas that comes out and go from there. </TD></TR></TABLE>
definately drain that gas
(i'm pretty sure there is a drain plug, correct me if i'm wrong
</TD></TR></TABLE> yes i would change the tranny fluid
Do i need to change the fuel/air filters?</TD></TR></TABLE>
the injectors are probably ok
you might also change the pcv valve, dizzy cap, and rotor
) <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eclectic211 »</TD></TR><TR><TD CLASS="quote">
Thanks so you think the power steering fluid should be ok.....I'm thinking i'm going to change everything else might as well do that as well
I guess i've got all the bases covered hope this goes well I'll let you know
longskate87
13
Nov 5, 2014 02:13 PM
