no brainer h22 head Q
i had a brain fart! and i need double check my info. ANY year h22 will head fit on a newer h22a4, right? cause i blew my h22a4 i had in my 97 civic. screwed up the head real bad but the block is still salvageable. i snapped a valve spring retainer and a intake valve ,that shot the valve into the piston and the piston hammered it into the head, when i took the head off the valve was pressed into the valve seat sideways. i'm still bummed out about it-
Entheogen
Engine Machining & Assembly
Sep 22, 2015 02:35 PM
