sway bar help (98 civic coupe)
Old May 15, 2004 | 05:37 PM
o d i e e's Avatar
Default sway bar help (98 civic coupe)
ok so here's the problem. about a month ago i recieved and install my rear sway set. (SRR) (sway and tie bar) installed and good to go. as i said its been about a month. since then i have taken one run through the canyons wiht the rear set installed. well sometime last week i was heading home from the gf's. the freeway entrance from her house has a long straight and begins to bear left ever so slighty, so like i always do i pick up speed and take the turn at about 80 (yes it does seem kinda fast but it was the middle of the night so the freeway was pretty empty). as i was taking the turn the rear of my car took a sudden shift to the right with much body roll causing my tires to slip a bit. not thinking much off it i brush it off. next day im getting ready to adjust my coils and come to find out the bolt to one of the endlinks on my sway had broke (which probably caused the shift of weight). well i'll let the picture explain the rest.
as you can see the bolt broke in half and im missing a piece that holds the endlink to the bar.
so what do you think guys? jsut get a whole new endlink? my friend suggested that i get a grip of washers and a bolt and try and fix it.
sorry for the long story. jsut trying to be informative.
any suggestions would be great.
please dont waste your time if your gonna flame.
Old May 16, 2004 | 08:07 PM
o d i e e's Avatar
Default Re: sway bar help (Uphill.Specialist)
aww common guys...little help
Old May 17, 2004 | 08:17 PM
o d i e e's Avatar
please ?
chrisw85
Suspension & Brakes
Oct 24, 2006 01:02 PM
o d i e e
May 18, 2004 12:03 AM
o d i e e
Jan 13, 2004 04:45 PM
o d i e e
Jan 13, 2004 04:39 PM
