90 hf swap , HELP
Old May 15, 2004 | 04:22 PM
itr crx's Avatar
Default 90 hf swap , HELP
Can anyone help me just my b16 in a 90 hf hook up every thing but won't start, it keep turning and turning over , I think its not getting any spark, some 1 said on honda tech every thing will hook right up just change out the hubs, does any 1 knows what dizzy wires 2 hook up on the distributor, I think that's the problem on my swap, and does any1 know what wires to hook up on the ecu 4 the vte and others ..
Old May 16, 2004 | 01:24 PM
itr crx's Avatar
Default Re: 90 hf swap , HELP (itr crx)
**** man can anyone help me please
Old May 16, 2004 | 02:27 PM
deftones0817's Avatar
did you convert it to obd1 or is it obd0? we need more info what ecu you using? What year b16a let us know some more info...ill be waiting for your replies
DEF
Old May 16, 2004 | 03:14 PM
itr crx's Avatar
Default Re: 90 hf swap , HELP (deftones0817)
I got a 1st gen b16 and it obd0, I hook up it in my 90 crx si just fine , but when I try to put in my 90 hf, every thing went in fine , but it won't start..
Old May 16, 2004 | 04:01 PM
K what ecu u running? Have you rechecked your wiring how did you wire distributor?
DEF
Old May 16, 2004 | 04:54 PM
4gCRX's Avatar
There aren't any wires you need to hook up on the distributer. Double check your grounds, specially the often forgotten one on your transmission.
You need to hook up vtec, knock, 2nd O2, and oil pressure switch. Here's one of many sites:
http://b16a.honda-perf.org/theswap.html
Old May 16, 2004 | 04:56 PM
Skinnypunk's Avatar
Is it out of gas?
Not trying to be funny but my dumbass had a similiar problem one time and that was the problem.
SiCRX90
19
Dec 15, 2006 06:42 AM
davesrex
Dec 22, 2005 07:54 PM
InMyProject
Feb 17, 2005 01:03 PM
crxhf19
Jan 30, 2005 07:41 PM
crxnotworking
Mar 16, 2004 06:33 PM
