lightening a itr flywheel to 10lb?
Old May 15, 2004 | 03:36 PM
tekstyle's Avatar
Default lightening a itr flywheel to 10lb?
u guys think its possible to do this?
Old May 16, 2004 | 02:41 PM
IntEGNYC's Avatar
Default Re: lightening a itr flywheel to 10lb? (tekstyle)
no. Honda has a service bulletin against modifying the stock flywheel.
It makes no reference to aftermarket ones so you'll need other references there.
Old May 16, 2004 | 03:10 PM
Ramocheese's Avatar
Default Re: lightening a itr flywheel to 10lb? (IntEGNYC)
Modifying a stock flywheel is a bad thing to do.
If you have ever seen pictures of lightened stock flywheels on various cars exploding, you'll see why. It can total a car, and even kill someone if pieces fly out the right direction.
Your best bet would be an ACT flywheel for a good priced light flywheel (usually they're like 12lbs or so). The only downside is that once the surface is out of spec for machining, you'll have to replace the flywheel.
The Fidanzas are very very nice, is extremely light (usually 8-10lbs), but is a bit pricey. The plus side to going with one is that you can replace the surface on it with a new surface once it needs to be machined, and keep the flywheel. Replacement surfaces are generally $130-$150 from what i have seen.
Old May 16, 2004 | 04:45 PM
spoolindc2's Avatar
just buy a lightened flywheel... lots o' companies make em and its just a little more than trying to lighten your existing one....
Old May 16, 2004 | 05:44 PM
tekstyle's Avatar
Default Re: (rjride1020)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjride1020 &raquo;</TD></TR><TR><TD CLASS="quote">just buy a lightened flywheel... lots o' companies make em and its just a little more than trying to lighten your existing one....</TD></TR></TABLE>
i just went with your suggestion
leondx
Honda CR-V & Element
Mar 3, 2013 05:08 AM
brianmcivics
12
Nov 23, 2007 02:17 PM
whitehf
Feb 4, 2006 05:20 AM
B_CRUZ!
Jan 18, 2002 06:43 PM
