Anyone have pictures of exhaust pipe running under the gas tank?
Old May 15, 2004 | 02:54 PM
AlphaKennyWun's Avatar
Default Anyone have pictures of exhaust pipe running under the gas tank?
I want to do a custom thing and want some ideas. Kind of like WRXs have them. Thanks
Old May 15, 2004 | 03:00 PM
Default Re: Anyone have pictures of exhaust pipe running under the gas tank? (Turbo Chris)
here are some wrxs..hmm
Old May 15, 2004 | 05:47 PM
maxspeedhonda's Avatar
This is how I used to have my EG when it had exhaust (keep in mind it is only 2.5 inch)
Old May 16, 2004 | 10:58 AM
DD_JonnyLee's Avatar
Default Re: Anyone have pictures of exhaust pipe running under the gas tank? (maxspeedhonda)
anyone have pics like these on a 94-up teg???
Old May 16, 2004 | 11:13 AM
swlabhot's Avatar
Default Re: Anyone have pictures of exhaust pipe running under the gas tank? (Raped-Ape)
On my 98' ITR ;
Old May 16, 2004 | 06:03 PM
Default Re: Anyone have pictures of exhaust pipe running under the gas tank? (swlabhot)
swlabhot, that looks hot. it looks like you ran the exhaust straight back following the stock groove until the end where you just shot across under the floorboard, to the cross member bar. The only place its low is when the exhaust is not in the groove right? How do you tihnk a 3" would do there? thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swlabhot &raquo;</TD></TR><TR><TD CLASS="quote">On my 98' ITR ;
Old Dec 24, 2004 | 07:19 PM
usdmcivic94's Avatar
What kind of muffler is that maxspeedhonda in your picture?
Old Dec 24, 2004 | 07:54 PM
eg crunkmonster's Avatar
Default Re: Anyone have pictures of exhaust pipe running under the gas tank? (usdmcivic94)
man, if u search u would find some and from what ive seen, if u want it going under the gas tank/trunk, that ish is gonna scratch the ground all day unless ur car is not lowered
Old Dec 24, 2004 | 09:43 PM
5thgencivic's Avatar
Default Re: Anyone have pictures of exhaust pipe running under the gas tank? (eg cookiemonster)
I don't think I have scraped mine yet except for the tip backing in my friends driveway that has a huge uphill hump in it. Only pic I have...
Old Dec 24, 2004 | 09:51 PM
W O T's Avatar
Default Re: Anyone have pictures of exhaust pipe running under the gas tank? (5thgencivic)
Just not worth it for the ground clearance you have to sacrifice
Side exhaust is what i went with, 88 Crx with 4feet of 3" exhaust with no cat/muffler/resonator, 314whp = ******* bad ***
Old Dec 25, 2004 | 01:59 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: Anyone have pictures of exhaust pipe running under the gas tank? (W O T)
hahaha.. yeah, im gunna make like a dump tube on my CRX just behind the pass front tire.
thomasw91
Aug 10, 2011 06:25 PM
DA_DRE
Welding / Fabrication
27
Apr 4, 2008 03:08 PM
Fallen86
10
Jan 7, 2006 02:19 AM
wrXtian
10
Sep 14, 2005 10:26 PM
Ill
Oct 6, 2003 12:06 AM
