wearing out rod bearings
Replaced new rod bearing on my 3rd cylinder, 30 minutes later after running, the bearing is wiped out. Has anyone had this experience? what did you do to fix it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xTravBx »</TD></TR><TR><TD CLASS="quote">Wrong bearing, most likely.
Did you check and see if the rod needed machining?</TD></TR></TABLE>
Or the crank too. Was the crank/rods machined in any way before install? Note that Honda doesn't have oversized bearings. If the crank/rods were machined, then you'll have to get some other aftermarket bearing.
In my case, I used Clevite bearings.
JDM turbo DC
Nov 28, 2006 12:37 PM
