problem with engine swap del sol...
Old May 15, 2004 | 02:40 PM
sikcrx80's Avatar
Default problem with engine swap del sol...
ok guys need info..
friend of mine is swaping a b16 hydro in his del sol (was sohc vtec) and he bought avid mounts and he got del sol dohc drive shafts and now with the car all together is shakes really bad and we cant seem to find out.
oh hes got the LSD in it too.
Old May 15, 2004 | 02:55 PM
sikcrx80's Avatar
anyone.. with alittle info
Old May 15, 2004 | 10:53 PM
sikcrx80's Avatar
cmon anyone
Old May 16, 2004 | 12:35 AM
Zerob16eg's Avatar
need a little more info......does it shake at high speeds? when mine did that i found out it was my axel. could also be a loose mount but i would check your axels first.
Old May 16, 2004 | 05:27 AM
Rod.'s Avatar
Default Re: (Zerob16eg)
tighten the motor mount bolts down properly? The motor mounts could cause it to shake. When I put my inserts in I could tell a difference and there was more vibration
Old May 16, 2004 | 06:17 AM
Sliced Beard's Avatar
Default Re: (redturbocivic)
are you shure it isn't chassis flex
if you have the top off it is really noticeable
Old May 19, 2004 | 07:21 PM
sikcrx80's Avatar
well.. he hasnt taken it up to high speeds...
i myself havent been in it but he says it shakes now i think it shakes more with the wheels turned alittle bit..
do u think the lsd could have somthing to do with it
ryanjoseph
Mar 7, 2008 05:43 PM
Bong29007
Oct 10, 2005 05:52 PM
roosta 1
May 18, 2005 09:18 PM
mongrill
Nov 27, 2003 11:41 AM
JDM HYBRID
Feb 25, 2002 11:47 AM
