cam gears...b series and h23 = same part# from aem
Old May 15, 2004 | 01:27 PM
Nikoli's Avatar
Default cam gears...b series and h23 = same part# from aem
i am about to get some cam gears and noticed that AEM has the same part# for
the h23 and b series engines. does that mean the other companies b series
gears will fit the h23 too?
if so that means i have more options than i thought what do you guys think?
Old May 15, 2004 | 01:39 PM
RABHonda's Avatar
Default Re: cam gears...b series and h23 = same part# from aem (95deckedlude)
its all about the tooth count, crank/cam pulley ratio.
Old May 15, 2004 | 02:21 PM
Nikoli's Avatar
Default Re: cam gears...b series and h23 = same part# from aem (RABHonda)
so then they are all the same i assume?
Old May 16, 2004 | 09:03 AM
Nikoli's Avatar
bump
Old May 16, 2004 | 10:32 AM
Whitfield Inc.'s Avatar
H23 non vtec dual cam motor IS the same as the b-series cam gears
H22 is all alone
Old May 16, 2004 | 01:03 PM
LudeyKrus's Avatar
Whoa, for real?
I never knew that!
Old May 16, 2004 | 04:43 PM
RABHonda's Avatar
Default Re: cam gears...b series and h23 = same part# from aem (RageDzine)
how is it all alone? if they both count 38/40 teeth, than they are sime diameter and crank/cam ratio.
Old May 16, 2004 | 07:24 PM
I am not at the shop right now so i cant give you the perfect anwser but they are different. The gear has the TDC mark in a different place witch makes it off a bit. But I will post tom with the exact reason - Sorry
Old May 16, 2004 | 07:39 PM
1700anddroping's Avatar
yes you are right about that.the tooth pitch is different.hey rage im me please.
Old May 16, 2004 | 11:07 PM
Nikoli's Avatar
Default Re: cam gears...b series and h23 = same part# from aem (1700anddroping)
so it is safe to say that i can use bseries cam gears then right?
Old May 17, 2004 | 07:57 AM
i don't see why not.i have some shunk 2's new in the bag for 150 plus shipping let me know.they are the 6 bolt.
Old May 17, 2004 | 08:12 AM
B-series will work great on H23 non vtec -
Old May 17, 2004 | 08:58 AM
Rtype16's Avatar
The B series cam gears part number 23-602 are the same for the B series and the H23 Perlue motor.
However the H22 uses a different gear they are smaller in diameter.
Cras-Delsol
Oct 4, 2008 07:05 AM
twowords
Jun 15, 2007 05:38 AM
Kamikaze Royale
Mar 16, 2007 09:34 PM
-TJ
Jan 16, 2002 02:35 PM
