Dirty Block
Old May 15, 2004 | 08:36 AM
Si Integra's Avatar
Default Dirty Block
I am not sure how, but when the machine shop did all my work, they hot tanked the block (so they say) and it is still pretty filthy. I have the short block still apart and wanted to sand blast it, I am woried the blast may make it in to the cylinder walls or the crank, etc. Does anyone have any ideas how I can blast it to clean it to make it loook new?
I do not want to paint over the dirt or anything and really did not want to paint it at all, but I do not want a disgusting looking block either.
I am open to suggestions and hope someone can help me out here.
FYI, the block is still unassembled, it has been thoroughly cleaned inside and the honing is done already as well.
Thanks
Old May 15, 2004 | 08:42 AM
boosted_dc2's Avatar
Default Re: Dirty Block (Si Integra)
just tape everything REAL well, and use bead blast instead of sand if your worried. or just sand the outside well then paint it.
Landon
Old May 15, 2004 | 11:10 AM
Si Integra's Avatar
Default Re: Dirty Block (boosted_dc2)
I thought to sand it with like a 800 or 600 grit, but I was worried the metal flaking may leave residue?
Old May 15, 2004 | 11:19 AM
Danger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">just tape everything REAL well, and use bead blast instead of sand if your worried.
Landon</TD></TR></TABLE>
try that first .
Old May 15, 2004 | 03:31 PM
Si Integra's Avatar
Default Re: Dirty Block (JonnyDanger)
You guys don't think it will harm the internals, or cylinder walls? I am very nervous after spending 500 on machine work.
Old May 15, 2004 | 03:41 PM
alpha's Avatar
Clean the block with some cleaner/degreaser, tape as much as you can off where you don't want paint with masking tape and paint it. I use Dupli-Color High Heat Ceramic (Aluminum DH1606). I used it on my last block which had quite a bit of work done on and I will be using it on my new block.
Before ...
Before ...
Before ...
After ...
Before ...
Before ...
Before ...
After ...
After ...
After ...
Old May 15, 2004 | 04:12 PM
Danger's Avatar
your only blasting away at the surface , not changin the shape of it or anything . jus tape everything off like the other guy said . you should have nothing to worry about
Old May 15, 2004 | 04:22 PM
Sonny's Avatar
I used full strength Castrol Super Clean to clean my block and it did a terrific job! I couldn't believe that that kind of cleaning power is available in a non-solvent.
Sonny
Old May 15, 2004 | 04:41 PM
MooreBoost's Avatar
Default Re: (Sonny)
Try using BrakeKleen, really strong stuff.
Old May 15, 2004 | 06:08 PM
Si Integra's Avatar
Default Re: (tegunderpressure)
I am goin gto try to just clean it well with chemicals first, if all else fails, I will go with the beads..
thegatekeeper14
Apr 13, 2011 01:52 PM
jdmkidd23
Paint and Body
Apr 22, 2008 12:32 PM
NATEDEEZY
19
Mar 26, 2008 04:28 PM
lude98SH
12
May 14, 2007 10:54 AM
Chuckles
Mar 10, 2002 08:59 PM
