Soooo....How much $$$$ do u all have in your fi project car????
Old May 15, 2004 | 08:10 AM
99lspwr's Avatar
Default Soooo....How much $$$$ do u all have in your fi project car????
I am sure you all have sat around with a calculator before and added up all the hard earned dollars that have been dumped into your ride.....I personally have $6055.00 tied up in my current project...Count the other $4759.00 worth of parts that got carried over from previous cars, that brings the grand total for me up to $10814.00..........So, lets hear it phellas...
WARNING!!!!!Doing this may cause a few tears to your eyes!!!But it was all worth it........Right????
Old May 15, 2004 | 08:25 AM
Joseph Davis's Avatar
Default Re: Soooo....How much $$$$ do u all have in your fi project car???? (99lspwr)
I'm rolling up on $5000 for everything, including the car itself. I'm about to go to my third engine/transmission/clutch/turbo/manifold combo, this incarnation even looks somewhat professional.
My boy Travis just dropped $12K on his, in addition to the $4000 he spent on his Integra, and should have it running by Tuesday or Wednesday. His feelings got kinda hurt when I pointed out midway through a $8K build that at 425 whp he'd have the power to weight of my CRX at 260 whp, so he dropped all sorts of money on a Quaife, some BFG drag radials that stick out of his wheel wells by 3", etc.
Old May 15, 2004 | 08:27 AM
Rah Rah's Avatar
Default Re: Soooo....How much $$$$ do u all have in your fi project car???? (J. Davis)
If my wife knew......
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
D16Y8 - free, came with the car
used greddy turbo kit, complete - 900
ACT HDSS clutch kit, new - 300
DRAG III FMIC w/piping - 300
Apexi V-AFC, used from buddy - 100
DSM 450cc injectors w/clips - 50
2.5" test pipe w/o2 sim - 50
2.5" exhaust - 200
gauges w/pod - 100
Total: $2,000
Boost: Priceless
Old May 15, 2004 | 08:32 AM
99lspwr's Avatar
Default Re: Soooo....How much $$$$ do u all have in your fi project car???? (boostincoupe)
Nice.....Keep them comin....BTW, my total also includes the price of the car....The idea behind this was to see the 100% total investment...Cheaper the better imo, but I know some of you honda-tech gangstas have some serious $$$ wrapped up in your rides.....
Old May 15, 2004 | 08:35 AM
91civicDXdude's Avatar
estimated $3000
car cost : $100
I've went through 6 engines. 6 countem. d15b2, d16z6, b18a1, d15/y7, d15/y7, d16y7/z6
2 turbos, 14B & .42/.48 T3
comp 59300 cam
FMIC, BOV and all other turbo goodies, VAFC, and the like.
Old May 15, 2004 | 08:45 AM
turboteg2nv's Avatar
Default Re: (91civicDXdude)
spent 8k for the ride, about $1800 so far in parts, still need about another $500 to finish a quality setup....ouch. maybe i should've payed more attention to that warning
Old May 15, 2004 | 08:47 AM
boosted_dc2's Avatar
car cost 7500
1st kit 2500
2nd wave an addtional 2000
motor 3100
total 15,100, not including exhast, guages, paint, wheels, brakes etc.
Landon
Old May 15, 2004 | 08:56 AM
Sohc Driver's Avatar
*Brand new 00 Honda Civic EX coupe-Free (Gift from my parents)
*01 B18B 10,160miles from Import Auto Salvage-2700
*Labor for swap-650
*(New) ACT HD Clutch/Street Disc w/ ACT streetlite flywheel-630
*(Used) SFP turbo manifold-230
*((New) Garrett T3/t4 turbo 57trim 63ar-600
*(Used) Greddy Type S BOV w/flange-170
*(Used) Tial WG w/flex dump tube-190
*(Used) Guage cluster bezel-30
*(Used) 2-guage pod-20
*(Used) Hondata s200b-350
*(Used) Apex'i Intercooler piping-25
*(Used) Precision 350hp Intercooler-280
*(New) Custom 4bolt downpipe-180
*(Used) Greddy 52mm egt and boost guage-210
*(New) Greddy Turbo Timer-80
*(Used) Greddy Profec B w/remote switch-200
My Total Cost <U>$6,545</U>
Unfortunately the swap is in, but the turbo kit isn't...I still need to buy some 550cc injectors, oil feed lines, greddy 52mm oil pressure and water temp guages, a few other miscellaneous parts, and finally tuning. So the money pit will probably end up being a little over $7,000. Wow...I never realized how much I spent until now Kinda scary yo!
Khoi
Modified by Sohc Driver at 12:13 PM 5/15/2004
Old May 15, 2004 | 09:05 AM
DIRep972's Avatar
Smarter than you
Sometimes its not about how much you spend but if you did it right, how much fun you had, and how much you learned.
Old May 15, 2004 | 09:06 AM
macrosshn's Avatar
the son and the heir
Default Re: (boosted_dc2)
When I initially went to piece my kit, I intended on going the 'cheap boost' method, but as many of you know, the best intentioned plans rarely work out. I wanted to buy used parts whenever it was availiable or maybe a used pieced kit form Drag or Rev-Hard. But after a ton of researching and browsing other people's set-ups, I changed my mind big time and now buy everything new or to my own liking. Thanks alot you asses, I mean guys, for making me go deeper in debt. Heres the breakdown:
96 ek hatch with B18c completed= 12,000
LoveFab SST and downpipe used= 900
Garrett Gt28rs= 800
Greddy type 24 intercooler= 420
Apex'i Twin chamber bov= 120
Tial 38mm wastegate= 200
Hondata s200b and P28 and jumper harness= 500
Walboro pump= 100
AEM fpr= 40
piping, oil lines and fittings= 400
So far the running total plus the car is $15, 120.00 and I still need injectors, a fuel rail and tuning. Hell, it isn't even installed yet. God-dayum
Old May 15, 2004 | 09:07 AM
gdrum's Avatar
Default Re: (Sohc Driver)
$6800 for 95 si hatch, h22, suspension, i/h/e, slipstreams, lip
$2800 turbo kit t3/04e, lovefab shorty660s, 2.5" piping, 3" dp, wideband, gauges, uberdata so on so on
$150 Si wheels and tires
$95 Ground Control Coilovers
$175 RSX black leathers front and rears
Got the car in octoboer with bolt-ons so everythign has been done since then....not to bad...but man since i added it up almost makes me sick
Old May 15, 2004 | 09:42 AM
roydogg's Avatar
Default Re: (gdrum)
I lost track
Old May 15, 2004 | 09:47 AM
vaporboy12's Avatar
Default Re: (roydogg)
car $750
turbo and all aftermarket stuff like $6000
Old May 15, 2004 | 09:55 AM
99lspwr's Avatar
Default Re: (gdrum)
I feel as if I could have saved some money here and there, but I wanted to do the car right the first time...I have had very good luck with my car, so I cant complain too much........
BlownVR's Avatar
well heres the old setup that my older brother had:
93 civic hatch
h23 block fully built by r&d dyno
h22 dohc vtec head fully built by r&d dyno
h22 trans w/ clutchmasters stage 5 clutch,lightweight flywheel,quiffe lsd
all the bolt ons:
venom manifold
venom fuel rail
rc 880 cc injectors
walbro fuel pump
aem stand alone
str throttle body
str cam gears
moroso oil pan
head gasket
arp studs
turbo setup:
custom turbo manifold
tial 46 mm wastegbate
hks ssbov
turbonetics t4 w new compressor
3 inch downpipe
thermal 3 inch exhaust
3 inch charge piping
greddy front mount
im prolly forgetting some **** but the grand total for the motor alone was $10,654 with the turbo kit!
and the car had wheels,cf hood,wing,full suspention, and nice interior.
i have just totaled up the reciepts and it came out to be a grand total of:$19,876
Old May 15, 2004 | 09:57 AM
m R g S r's Avatar
Default Re: (vaporboy12)
I am not sure on the exact cost, but I have been working since I was 15, bought the car when I was 16, and now I'm 17. I bought the car for $7k, and at the time I had $3k saved. Within a few weeks that $3k was gone (I don't know how, but it was waisted on my car) And since then, I have probally added another $5k worth of parts. And I still didn't even buy my turbo parts yet!!!
Old May 15, 2004 | 10:26 AM
mildly.interesting's Avatar
Default Re: Soooo....How much $$$$ do u all have in your fi project car???? (Rah Rah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rah Rah &raquo;</TD></TR><TR><TD CLASS="quote">If my wife knew...... </TD></TR></TABLE>
this afternoon when I pick it up from P1, and part with my gangster roll in my pocket, I'll be 11K in.
on a car that has a tax value of 1400 bucks
Old May 15, 2004 | 10:35 AM
FOrSfEd's Avatar
Default Re: Soooo....How much $$$$ do u all have in your fi project car???? (mildly interesting)
00' Integra R- 16,000
Parts- 6500.00
Total- 22,500.00
Old May 15, 2004 | 10:53 AM
BodyKits NW's Avatar
Default Re: Soooo....How much $$$$ do u all have in your fi project car???? (FOrSfEd)
Too much!
Old May 15, 2004 | 11:00 AM
5STAR3's Avatar
Default Re: Soooo....How much $$$$ do u all have in your fi project car???? (BodyKits NW)
im about 13k into a 92 cx hatch
just motor and turbo ~5k
Old May 15, 2004 | 11:10 AM
Danger's Avatar
i get depressed everytime i think about how much i have spent . after i wrecked my old turbo integra i wanted to build somethign that was complete from the motor , interior , to the exterior . since i knew i was going to take the car completely apart i didnt see any reason to go out and dump a **** load of money on a running car . i found a 98 gsr shell in a wrecking yard and picked that up . well that was almost 2 years ago !
some mods....
98 gsr shell - 1200
bodywork/ paint - 4000
oem metal jdm front endw/ hids - 2200
4x114 suspension w/ 16" Racing hart CP-Rs - 1000
DTR fab roll cage and traction bars - 1200
ApexN1 coilovers , ITR lcas - 850
Recaro srds - 1000
Spoon cluster -500 (bought that like 2 years ago )
there are more but i wont take up the whole thread..
motor....
98 b18c5 block - 500
GE sleeves - 750
crower rods - 650
84mm ross pistons - 550
z10 block girdle - 200
act flywheel - 200
act HEAVY duty clutch - 200
TODA timing belt - 150
Hasport mounts - 350
machine work - 350
01 ITR head - 500
rev valves , springs , retainers - 600 (bought like 2 years ago)
CBI race head - 600
thats around $17,000 that i have spent so far and im not done yet . also the price didnt include all the parts that i had to buy to complete it , for example....hatch , rear bumper , taillights , etc....i know i havent actually purchased a turbo kit yet but its all part of my turbo project
i jus wanna say thanks to all the people that have helped me out here on H-T
Modified by JonnyDanger at 4:33 PM 5/15/2004
Old May 15, 2004 | 11:53 AM
G_Man604's Avatar
Default Re: Soooo....How much $$$$ do u all have in your fi project car???? (JonnyDanger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonnyDanger &raquo;</TD></TR><TR><TD CLASS="quote">i get depressed everytime i think about how much i have spent .
same here! Im guessing I dropped 30 g's (canadian) on the motor I stopped counting after 20 hahaha
Old May 15, 2004 | 12:35 PM
calib17a's Avatar
But alot of us can beat cars costing 2-3 times the $$$$
Old May 15, 2004 | 12:41 PM
94gsr4dr's Avatar
Default Re: Soooo....How much $$$$ do u all have in your fi project car???? (calib17a)
parts only including all motor parts before deciding to go turbo probly around 12-13k not including tires, slicks, brakes, suspension. With car and those parts probly around 20-22k more with labor.
