Old seats = wear... anyone tackle fixing them?
Old May 15, 2004 | 06:53 AM
splitime's Avatar
Default Old seats = wear... anyone tackle fixing them?
I know there are shops that handle stuff just like this. But for the prices they charge you could just get a replacement ... car.
So I'm curious, has anyone attempted to find similar foams (not oem, its insanely expensive also) and "rebuild" the seat bolsters on our older worn out seats?
I'll most likely be trying it with some couch style foam and shaving it to a semi close fit. Then stuff it in and redoing the material at the area with a similar fabric, or just patching the teeny hole i've go in one location.
If you have redone your seat, share ideas/info about materials, technique, results All info is helpfull and welcome.
Old May 15, 2004 | 08:21 AM
crx_88_si's Avatar
Default Re: Old seats = wear... anyone tackle fixing them? (splitime)
Actually.. I was recently enlighted. Most of the time it's the Driver seat outside bolster that gets chewed up. But the pass side is usually still mint. You can buy a used pass side seat and swap the foams over to the driver side.
This is what I am planning on doing.
Note. I figured it would be easier to swap the seat belt/buckle assem. to the pass side seat. apparently, it's not possible that way.
Old May 15, 2004 | 08:24 AM
spaceman's Avatar
find some seats on ebay or something
Old May 15, 2004 | 08:25 AM
splitime's Avatar
Default Re: Old seats = wear... anyone tackle fixing them? (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">Actually.. I was recently enlighted. Most of the time it's the Driver seat outside bolster that gets chewed up. But the pass side is usually still mint. You can buy a used pass side seat and swap the foams over to the driver side.
Note. I figured it would be easier to swap the seat belt/buckle assem. to the pass side seat. apparently, it's not possible that way.</TD></TR></TABLE>
I was actually considering swapping the rails with the passenger seat and sticking the pass. with the bum seat
Old May 15, 2004 | 08:27 AM
spaceman's Avatar
sounds good
Old May 15, 2004 | 08:33 AM
crx_88_si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">
I was actually considering swapping the rails with the passenger seat and sticking the pass. with the bum seat </TD></TR></TABLE>
then you're seat belt would be on the wrong side.
Old May 15, 2004 | 08:50 AM
splitime's Avatar
then you're seat belt would be on the wrong side.</TD></TR></TABLE>
I don't mean just rails... i mean the entire rails/tilt assembly. Should have said it clearer.
Old May 15, 2004 | 09:09 AM
b16_madman's Avatar
you can swap the seat foam and fabric from drivers to pass side correct? my pass one is mint and my fatt butt has ragged out the drivers
Old May 15, 2004 | 11:45 AM
crx_88_si's Avatar
Default Re: Old seats = wear... anyone tackle fixing them? (B16_madman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16_madman &raquo;</TD></TR><TR><TD CLASS="quote">you can swap the seat foam and fabric from drivers to pass side correct? my pass one is mint and my fatt butt has ragged out the drivers</TD></TR></TABLE>
yes.. thats what im plannin on doing. Just waiting for that "person" to get back to me
Old May 15, 2004 | 01:45 PM
sporkcrx's Avatar
I'm subscribing to this because I would really like to get some side support in my seats without buying new ones. Think there's a way to take out material in the backing so that you sit back farther, and be "hugged" more by the seat?
Old May 15, 2004 | 02:55 PM
Rywire's Avatar
Default Re: Old seats = wear... anyone tackle fixing them? (sporkcrx)
Ok, I have first hand knowledge on this subject. I bought a crx pass side seat on ebay, and put it on my driver side. The backings are very close, but not exact. You cant notice, http://www.droppedcrxsi.com under pics to see a pic. You must strip the backings down to the frame, and swap them over. Also a small knotch needs to be made in the side of the foam to work right. The bottoms can be taken out of the pans, and swapped over. They dont fit great, and you need some metal wire to help snug them up. Also the bottoms are a different shape, but close. In person, Nobody has ever noticed that it was a passenger side seat. Ryan
Old May 16, 2004 | 10:34 AM
b16_madman's Avatar
Default Re: Old seats = wear... anyone tackle fixing them? (droppedcrxsi)
cool man, i'm bout to go outside and play w/my seats
Old May 16, 2004 | 01:29 PM
hybridbmw's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">Ok, I have first hand knowledge on this subject. I bought a crx pass side seat on ebay, and put it on my driver side. The backings are very close, but not exact. You cant notice, http://www.droppedcrxsi.com under pics to see a pic. You must strip the backings down to the frame, and swap them over. Also a small knotch needs to be made in the side of the foam to work right. The bottoms can be taken out of the pans, and swapped over. They dont fit great, and you need some metal wire to help snug them up. Also the bottoms are a different shape, but close. In person, Nobody has ever noticed that it was a passenger side seat. Ryan</TD></TR></TABLE>
I did the same exact thing you did. Came out perfect, nobody could ever tell that the foam and material was from a passenger seat.
Old May 16, 2004 | 02:18 PM
splinter51's Avatar
Default Re: Old seats = wear... anyone tackle fixing them? (speedaholic)
well if you guys were close my dad does upholstery, he made some cool seats from the stock stuff. just cut out nasty foam and replace with good. use eletric knife to shape as desired. then you can get diff. stiffness of foam to suit your likeness.
Old May 16, 2004 | 03:11 PM
MooreBoost's Avatar
I thought about that, but that would leave the hole in the middle of the car, alot more visible. Im just going to get som Si seats for like 200 bucks.
Rice For Dinner
Jan 31, 2012 07:02 PM
wahee
May 19, 2011 12:18 AM
EZ99B5
Acura TSX
Nov 24, 2008 09:46 AM
Driven
15
Jun 10, 2005 11:28 PM
civicrr
12
Aug 9, 2002 08:53 PM
