problem with my Hasport cable to hydro conversion
Old May 15, 2004 | 12:15 AM
red civic standard's Avatar
Default problem with my Hasport cable to hydro conversion
I ordered the Hasport EFB2 kit to put a hydro tranny in my EF. Motor and tranny are installed.
Here is the problem that I am having with adjusting the clutch cable....i have to tighten it a lot to get the clutch pedal to the point where I can put the tranny into the different gears, but at that point when I let out the clutch it never fully disengages (i know this because the clutch is slipping at 1/2 throttle). The clutch is brand new, so I know it is not the clutch.
Is my cable stretched? Has anyone had any similar problems?
Old May 15, 2004 | 01:05 AM
EL Vap133's Avatar
Default Re: problem with my Hasport cable to hydro conversion (red civic standard)
Cable is probably strectched, it happened to me and I couldn't shift gears, damn piece of crap clutch cable. It snapped and whoala!
Old May 15, 2004 | 04:49 AM
Default Re: problem with my Hasport cable to hydro conversion (EL Vap133)
where did you get a new one?
Old May 15, 2004 | 05:26 AM
deftones0817's Avatar
I think you can either get a 90 - 93 integra cable or a 88-91 crx cable for replacement at the honda dealer. I would get a 90 -93 cable.
DEF
Old May 15, 2004 | 08:42 AM
crx_88_si's Avatar
Default Re: problem with my Hasport cable to hydro conversion (deftones0817)
cable is too short. 90-93 required.
Old May 23, 2004 | 03:36 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
these converiosn kits... can just the converision be purchased.. or do you have to get the whole mount kit again.. i ahve the place racing front crossmember, and all 4 mounts.. i dont' wanna change mounts..
Old May 23, 2004 | 11:03 PM
AychTwenee2's Avatar
We just did an H22 in a 90 hatch and made our own cable to hydro conversion. Screw paying for that ****. You have to buy the mount..............screw that! We make our own ****! And it works!!!!!
Old May 24, 2004 | 10:22 AM
Patch's Avatar
Default Re: (VeeTekCrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VeeTekCrx &raquo;</TD></TR><TR><TD CLASS="quote">We just did an H22 in a 90 hatch and made our own cable to hydro conversion. Screw paying for that ****. You have to buy the mount..............screw that! We make our own ****! And it works!!!!!</TD></TR></TABLE>
Old May 24, 2004 | 10:24 AM
BTLFED's Avatar
So what? Was that the question he asked?
It sounds like the cable is bad. I would use the 90-93 cable.
Old May 24, 2004 | 10:36 AM
RobbieG35's Avatar
12 Years Strong
Default Re: (BTLFED)
Thanks for the insight, red civic standard is so much closer now than he was because of this pointless post of yours
EL Vap133's Avatar
Yeah, I got the 90-91 Teg clutch cable from Acura and now my car shifts smoothly and the pedal isn't as hard.
Old May 24, 2004 | 12:31 PM
switched to a 90-93 integra clutch cable and the tranny is operating normal.
pedal feel is extremely stiff due to the conversion.
If I tighten the cable a lot, the clutch starts slipping in 5th gear. I wonder if my clutch is bad. It looked decent when I threw it in there.
Old Jun 18, 2004 | 09:10 PM
ENeRg3Tic's Avatar
when you installed the kit did you have to order another mount from hasport ?? for the timing belt side
Old Jun 18, 2004 | 09:25 PM
Rywire's Avatar
Default Re: problem with my Hasport cable to hydro conversion (Built B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A &raquo;</TD></TR><TR><TD CLASS="quote">these converiosn kits... can just the converision be purchased.. or do you have to get the whole mount kit again.. i ahve the place racing front crossmember, and all 4 mounts.. i dont' wanna change mounts..</TD></TR></TABLE>
The whole kit would be necessary if you have a place racing kit because the hydro tranny mount is different(you could fab up something though). If place racing came out with a mount for the hydro tranny, they it would work. But... If they bothered to make a mount for the hydro tranny they might as well make a cable to hydro conversion too. Ryan
Old Jun 18, 2004 | 10:44 PM
Default Re: problem with my Hasport cable to hydro conversion (droppedcrxsi)
anyone else having problems with their clutch pedal being rediculously stiff?
my left leg is getting tired. I am considering putting in some EG hydro lines so that the tranny operates like normal.
Old Jun 19, 2004 | 12:26 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red civic standard &raquo;</TD></TR><TR><TD CLASS="quote">anyone else having problems with their clutch pedal being rediculously stiff?
my left leg is getting tired. I am considering putting in some EG hydro lines so that the tranny operates like normal.</TD></TR></TABLE>
I did at first. Then my cable took a dump. I got a brand new one from Honda and the pedal feels much lighter now!
Old Jun 19, 2004 | 02:28 PM
Rywire's Avatar
Ya, mine is stiff, but I had the same cable, and clutch before, and it was just about as stiff. Ryan
mikeyleed
Jun 24, 2014 04:36 PM
turbo-crx
Oct 7, 2008 02:45 PM
geces23
Nov 29, 2006 08:17 PM
dontgodumb
12
Jun 15, 2006 09:17 PM
DAmn
Jul 21, 2005 10:27 PM
