VAF-C questions??? need help
Old May 14, 2004 | 10:09 PM
smkngsr's Avatar
Default VAF-C questions??? need help
Just recently bought a vafc and it was actually used from civic SI...my question is..if i install this right now...do i need to do the initial set up according to the manual...and if i do the initial setting...what will be the setting on my car....my concern is...i will get them tune later on so i want to be on the safe side for few weeks til i take them tune...thanks for the feedback in advance
Old May 14, 2004 | 10:14 PM
EJ1 wilcox's Avatar
Default Re: VAF-C questions??? need help (smkngsr)
After you install it initialize the settings and set them according to the manual.
That's the safest way to go
It only takes a few seconds to do so you might as well.
Old May 15, 2004 | 05:49 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: VAF-C questions??? need help (koreanwilcox)
just leave it at default settings until you tune, because that will do no change to your car.
Old May 15, 2004 | 10:57 AM
LSTEG96's Avatar
Default Re: VAF-C questions??? need help (dLo GSR)
i cant get my throttle reading to show up
Old May 15, 2004 | 10:07 PM
EJ1 wilcox's Avatar
Default Re: VAF-C questions??? need help (LSTEG96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 &raquo;</TD></TR><TR><TD CLASS="quote">i cant get my throttle reading to show up </TD></TR></TABLE>
Go to "car select" or whatever it's called, then press the gas to the floor for 10 seconds. (with your car off obviously )
If you already did this and you still are having problems, re-check your wiring.
Old May 15, 2004 | 10:09 PM
LSTEG96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koreanwilcox &raquo;</TD></TR><TR><TD CLASS="quote">Go to "car select" or whatever it's called, then press the gas to the floor for 10 seconds. (with your car off obviously )
If you already did this and you still are having problems, re-check your wiring. </TD></TR></TABLE>
ah thanks, i may have been in the wrong mode menu thingy when i did that whole 10 second thing.
Old May 16, 2004 | 09:08 AM
mini-v-si's Avatar
Suggestion, best way is to follow the manual, if you don't have it download from the apexi site until you get it tune, I'm also in the same boat.
GreddyCivic7
Dec 27, 2006 05:08 PM
sublimenerd
Oct 23, 2006 12:37 PM
jdmh22luda
Jul 23, 2005 09:06 AM
JDM TypeR 307
Jan 5, 2004 10:39 PM
