Honda S2000 Honda S2000
widest rear tire for a S2k???
Old May 14, 2004 | 09:27 PM
JDMb18civic's Avatar
Default widest rear tire for a S2k???
can someone tell me wut it is the rim size will be 18x7.5
...and pics would help..
TIA
Old May 14, 2004 | 11:10 PM
SpeedXRacer's Avatar
Its either going to be 245 or 255.
Old May 15, 2004 | 07:57 AM
OC 335i's Avatar
Default Re: widest rear tire for a S2k??? (JDMb18civic)
Why so narrow in the rear?
Old May 15, 2004 | 04:09 PM
smallttocs's Avatar
you could probably fit at least a 285a on, maybe even b.
Old May 15, 2004 | 09:53 PM
steven975's Avatar
Default Re: widest rear tire for a S2k??? (smallttocs)
with the stock wheel, i think 245/45/16.
Old May 16, 2004 | 08:52 AM
nickgmiller04's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smallttocs &raquo;</TD></TR><TR><TD CLASS="quote">you could probably fit at least a 285a on, maybe even b.
whats the a and b mean??? i work in a tire shop and ive never heard that terminology.
Old May 16, 2004 | 10:04 AM
You guys forgot he added his rims are 18x7.5 in the back.
Old May 17, 2004 | 09:58 AM
Default Re: (SpeedXRacer)
thanks, but what offset should it be
Old May 17, 2004 | 10:53 AM
Revgasm's Avatar
Default Re: (JDMb18civic)
my buddy has 17x10 rear 17x9 front . . . 275 and 255's . . . CCW wheels...so dope!!! and they're AO32R's
Old May 17, 2004 | 11:47 AM
Scot's Avatar
Default Re: (Revgasm)
what the hell kind of wheel are you running? 18*7.5's sound like they are not even made for the S2000!
even TE37's are 8.5" wide in the rear.......
get proper wheels if you are going to do it.
Old May 22, 2004 | 09:46 PM
oos2kfan
Guest
Posts: n/a
Default Re: (Scot)
you can run 265/35s on the rear with that setup. That's what I'm running and I have 18 *7.5. Scot...not many wheels are made for one particular car. If you find the size and offset you need then you can use it. it doesn't have to be made with the S2000 specifically in mind. I run 4 18*7.5s on the street, but run stock 16's on the track for weight and handling purposes.
Old May 22, 2004 | 10:02 PM
Im not even sure 265]'s can fit on a 7.5" wide rim. My 9" wide rims can only fit 275's
Old May 23, 2004 | 07:53 AM
VinS2000's Avatar
Ive seen a 315 on a 9 inch rim. Sure it will buldge pretty bad, and people will tell you it wont fit, but it will. But as for the S2000, the biggest that I have heard of that people dont have problems with is 265's. I believe once you go bigger you will need to buy spacers. Anyways, I see no reason for any tire bigger then a 265 on the rear. I have 245's and they hook just fine. My friend with a S/C s2k has the same 245's and the still hook just fine. Unless you are just doing it for the "looks" of the big tire.. I see no reason to go past the 265.
Old May 23, 2004 | 07:55 AM
VinS2000's Avatar
Default Re: (VinS2000)
Also to answer your question. A 265 will fit on that rim without any trouble. It will buldge a little bit, but I assure you it will fit. I would recommend a 245/255 if you dont wany any buldging tho.
Old May 23, 2004 | 10:45 PM
brian_k03's Avatar
u wont be carving any canyons with a drag stylee setup though
Old May 24, 2004 | 12:07 PM
oos2kfan
Guest
Posts: n/a
Default Re: (brian_k03)
huh? as long as you stagger properly it won't affect your "canyon carving" abilities. You just need a little more meat in the back than you have in the front to keep the oversteer at bay.
Old May 24, 2004 | 08:43 PM
alternativechuck's Avatar
I have a 01 s2k with 19x10's in the rear and 19x8's in the front, (and they dont rub) roja custom made the wheels in 3 weeks, I will try to put up a picture on my website in a couple of days (alternativemotorsports.com), I have road raced the car and they still don't rub even lock to lock, and they look tight from the rear, and don't stick out. Price was about $1950.00 for the whole set with shipping
Old May 25, 2004 | 10:30 AM
01ITR
Guest
Posts: n/a
Default Re: widest rear tire for a S2k??? (alternativechuck)
19X 10.5 REAR------------19X8.5 FRONT biggest you can fit without modifing (www.hrewheels.com)
remeber rims make or break your car, choose them wisley
Old May 25, 2004 | 08:57 PM
Default Re: widest rear tire for a S2k??? (01ITR)
So do you know of some wider or bigger wheels that wont rub, and you don't have to modify?? If so let me know and I will check them out
Old May 25, 2004 | 11:49 PM
I know a couple of people who are running 285's in the rear without using any spaces at all. Im currently running 265's upgrading to 275's in about a week and I havnt had any problems at all thus far.
Old May 26, 2004 | 07:16 AM
Mr. Bagel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alternativechuck &raquo;</TD></TR><TR><TD CLASS="quote">So do you know of some wider or bigger wheels that wont rub, and you don't have to modify?? If so let me know and I will check them out</TD></TR></TABLE>
You do have to modify & roll the fenders for some fitments.
Also, you can fit 18x9's up front... but even at 8.5" wide, you'll probably need coilovers to increase the available room down there.
Old May 26, 2004 | 07:31 AM
FlyingDonkey's Avatar
I think 245 is better
Old May 26, 2004 | 08:09 AM
Mr. Bagel's Avatar
Default Re: widest rear tire for a S2k??? (owenxguo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by owenxguo &raquo;</TD></TR><TR><TD CLASS="quote">I think 245 is better</TD></TR></TABLE>
don't take this as bashing but...
- what are you talking about?
- why do you claim what you claim?
- what kind of driving are you talking about?
- for which wheel?
please back up your blanket statements that have nothing to do with the topic at hand.
Old May 26, 2004 | 08:14 PM
I have 265/30zr19's on the rear with 10inch wheel and 225/35zr19's on the front with a 8 1/2 inch wheel, the don't rub, even lock to lock and hard corners
b16ferio
Honda S2000
11
Oct 16, 2006 09:13 PM
HeavyFoot_Tony
Honda S2000
Dec 3, 2005 07:38 PM
s2khic
Honda S2000
16
Sep 29, 2005 01:54 PM
Mr. Lucky
Honda S2000
18
May 31, 2005 06:09 PM
NightHawkC5
Honda S2000
20
Aug 21, 2003 03:51 PM
