Help:Installing USDM crank angle sensor and oil pump
Old May 14, 2004 | 09:13 PM
2kgs-R's Avatar
Hello, I'm going to attempt to install a USDM oil pump onto my JDM B18C motor so I can pass smog, I have the crank angle sensor along with the USDM oil pump that I'm going to try and install so I can run an USDM ITR ECU with out a CEL.
The question I have is will I need a USDM crank gear or can I use the JDM one that's on the motor. I think there's a possibility that the JDM crank gear is different because it doesn't require a crank angle sensor but I'm not sure.
Does anyone have any experience installing a crank angle sensor and USDM oil pump onto a JDM motor?
I hope this makes sense.
Please help!
Old May 14, 2004 | 09:36 PM
esponet's Avatar
I have done this before.
You'll need the following USDM parts:
Crank gear
CFK sensor and bracket
Oil pump
Lower timing belt cover
Oil pump gasket
Wiring harness
BTW you will also need a USDM intake manifold for the EVAP solenoid and vacuum lines. You can ghetto rig the JDM one but they could fail you for it.
Throttle body, you need to remove the vacuum line (metal dick that sticks out) That goes to the canister. capping it will do, but again they could fail you for this also.
Old May 14, 2004 | 10:03 PM
2kgs-R's Avatar
Default Re: (esponet)
Thank you very much for the info. Do you have any idea where and how much a usdm crank gear costs, can I use any usdm crank gear from a obdII b series motor?
Old May 15, 2004 | 07:28 AM
skunkintegra's Avatar
Default Re: (2kgs-R)
i just have to comment....
2kgs-R-- your car is badass!!!
https://honda-tech.com/gara...=1637
Old May 15, 2004 | 10:13 AM
2kgs-R's Avatar
Default Re: (skunkintegra)
Thanks
Old May 15, 2004 | 12:15 PM
{Mineral Grey} ITR's Avatar
Default Re: Please help w jdm itr b18c***installing crank angle sensor! (2kgs-R)
Keep us posted if you pass smog
Old May 16, 2004 | 10:38 AM
esponet's Avatar
Any B-series OBDII crank gear should work, especially B18C and B16A.
if not wrecking yard, dealerships would have them
Modified by esponet at 4:34 AM 5/17/2004
Old Feb 27, 2007 | 05:58 PM
ricekiller1's Avatar
Default Re: (esponet) back from the dead
back from the dead...do by the crank gear? do they mean the timing belt drive pulley?? im looking to add the crank angle sensor also...thanks guys
Old Feb 28, 2007 | 07:53 AM
andyt's Avatar
Default Re: (esponet) back from the dead (ricekiller1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricekiller1 &raquo;</TD></TR><TR><TD CLASS="quote">back from the dead...do by the crank gear? do they mean the timing belt drive pulley?? im looking to add the crank angle sensor also...thanks guys</TD></TR></TABLE>
Yeah, I'm pretty sure thats what they mean. The timing belt drive pulley has the "teeth" that the sensor needs.
Old Feb 28, 2007 | 04:00 PM
Default Re: (andyt)
is there a write up on this add on somewhere???
Old Mar 5, 2007 | 07:09 PM
vtec4max's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esponet &raquo;</TD></TR><TR><TD CLASS="quote">I have done this before.
Crank gear
Oil pump
Oil pump gasket
Wiring harness
So what you're saying is there is a difference in the crank gear from OBD1 to OBD2?
Old Mar 6, 2007 | 08:36 AM
mathieucivic's Avatar
Default Re: (vtec_avenue)
I just do the switch.
You need the crank timing belt gear and the key to lock it. (not built in the gear like the jdm).
EGeezy
12
Dec 5, 2015 07:04 AM
EGeezy
Sep 25, 2015 11:44 PM
CW-ITR
Nov 19, 2012 06:14 PM
4DRPIMPIN
15
Apr 23, 2004 05:46 PM
