Hondata qusetion once again..
Old Nov 6, 2001 | 02:27 PM
SpeedMonkeyRacing's Avatar
Default Hondata qusetion once again..
Alright...think I'm going to go w/ HONDATA now while I rebuild my motor. I have FMAX turbo (two extra injector crap). What parts do you guys think I'll need? Right now..this is what I have in mind
JE PISTONS
Eagle Rods
A build head that I'm getting from a friend of mine (pnp..blah blah blah).
RC550
I'm thinking about getting Honda 4b (w/ all the goodies)..but what goodies do I really need to get? I'm so confused when I went to the website...any help would do!!
Jeff-
Old Nov 6, 2001 | 03:25 PM
smoothludey2's Avatar
New User
Default Re: Hondata qusetion once again.. (ProjectD2-Jeff)
get rid of the 2 injector crap and get 4 550cc RCs w/ and AEM fuel rail, AEM fpr, Walbro intank fuel pump, eagle sleeves, and think about your tranny...quaife? new clutch?
Old Nov 6, 2001 | 03:28 PM
immortal's Avatar
Banned
bah for the money of the hondata 4b you could get a speed pro bank system.....
also, i know someone who can get you eagle rods shipped to your door for $325. email me immy@home.com if you are interested.
[Modified by immortal, 4:28 PM 11/6/2001]
Old Nov 6, 2001 | 03:42 PM
Default Re: Hondata qusetion once again.. (smoothludey2)
i have clutch specialties stage 2 on it...it can hold up to 300 torque so i think that can last me for a while..
Jeff-
Old Nov 6, 2001 | 04:11 PM
TurboSedan's Avatar
New User
How do you like that clutch? Decent feel, not too stiff but grabs hard? Let me know, thanx.
Old Nov 6, 2001 | 04:16 PM
Default Re: Hondata qusetion once again.. (97CivicFerio)
feels like stock but grab like a ****
Jeff-
Old Nov 6, 2001 | 06:20 PM
TurboSedan's Avatar
New User
**** yeah that is what I like dude!!!
Old Nov 6, 2001 | 06:45 PM
DamonBoost's Avatar
New User
What can you get the speed pro bank to bank system for? Including tuning and installation??
Old Nov 7, 2001 | 08:14 AM
DamonBoost's Avatar
New User
Default Re: Hondata qusetion once again.. (Damon501)
just a little bumpy bump to tha top
Old Nov 7, 2001 | 09:45 AM
sagaprelude's Avatar
how much is a hondata?
Old Nov 7, 2001 | 11:30 AM
Tomakit's Avatar
Default Re: Hondata qusetion once again.. (sagaprelude)
Bringing this back on topic:
JE pistons
Eagle Rods
PnP head...I'd second guess that...but whatever...
RC 550
with all of that, get hondata stage 2b, unless you really see yourself dyno-tuning a lot. With stage 2+boost, the ECU will be able to read conditions under boost, but you will not be able to custom tailor (ie. burn new settings) unless you go to stage 4b. For your set-up and goals, 2b and a GM MAP sensor should be enough...for now. and if its not, you can always upgrade.
Tom
(o yeah, when you do get the hondata, im first in line for your v-afc)
Old Nov 7, 2001 | 01:52 PM
Default Re: Hondata qusetion once again.. (Tomakit)
JE pistons
Eagle Rods
RC 550
Tom
haha....now i'm debating if i should go w/ hondata or power fc...seems like power fc would be the right choice for me since I want to keep my AVC-R (to replace where I put my VAFC) and yes..you get the first dip when it's available
Jeff-
Old Nov 7, 2001 | 01:58 PM
DirtyLude's Avatar
I haven't followed you planning, but what does the Power-fc have to do with you keeping your AVC-R? Why wouldn't you ba able to use the AVC-R if you went with the Hondata?
Old Nov 7, 2001 | 02:10 PM
Default Re: Hondata qusetion once again.. (DirtyLude)
well, i could still use the AVC-R on hondata..but why? you can tune your boost on hondata....well, either or really don't matter because I will be using my AVC-R as my boost reading (dont' have boost gauge) anyway..
Jeff-
Old Nov 7, 2001 | 02:12 PM
DirtyLude's Avatar
I think you have something confused. Hondata does not include a boost controller.
Old Nov 7, 2001 | 02:46 PM
Dee's Avatar
Dee
The AVC-R looses it's gear based boost control when controlled by the Power FC! I know this because I have setup (3) P-FC with boost control kits. The P-FC also does not have a commercial datalogging program; the tuning tables while using the hand-held programmer aren't as fine as the Hondata, Speedpro,...; setting the base turbo map on a P-FC is a long and tedious process; ...
Hondata, Speedpro or Haltech would be a better choice!
Old Nov 7, 2001 | 02:55 PM
DirtyLude's Avatar
Default Re: Hondata qusetion once again.. (drealgsr)
The AVC-R uses the Vehicle Speed Sensor and ignition wire to guess the gear you're in. How does the Power-FC affect these that the AVC-R wouldn't be able to use them?
Old Nov 7, 2001 | 03:21 PM
Markaccord95's Avatar
Id get the 2b (I can get it for like $565 shipped) and find a good dyno and definately some 550ccs. When using hondata you do not need to really update the MAP til you get over a bar.
Old Nov 7, 2001 | 03:26 PM
Dee's Avatar
Dee
Default Re: Hondata qusetion once again.. (Markaccord95)
Dirtylude.. because the Power FC controls some much other stuff it can not control all of the features of the AVC-R. If a user wants to keep the gear based boost control the AVC-R would have to be used as a stand alone when used with the P-FC. We tried this forever on (2) FD3S RX-7's and a turbo CTR. When we called AP engineering they said "Gear based boost control is NOT available when the P-FC is used to control boost".
Old Nov 7, 2001 | 05:03 PM
turbod97ex's Avatar
New User
Hondata says you need the GM map sensor over 11psi. You are going to need an OBD1 ECU and harness too.
Old Nov 7, 2001 | 05:44 PM
Mikex25's Avatar
New User
Default Re: Hondata qusetion once again.. (turbod97ex)
you don't really need it unless you boost any higher then that.
Old Nov 7, 2001 | 07:33 PM
really, thought it was 1 bar when it was needed, my bad
yaaj1320
Apr 29, 2004 09:18 PM
1.8EG-T
Aug 27, 2002 07:11 AM
1.8EG-T
Aug 25, 2002 02:28 PM
H23ludedude
May 5, 2002 09:03 PM
