UNTUNED LS/VTEC
Old May 14, 2004 | 05:26 PM
gogou99's Avatar
Default UNTUNED LS/VTEC
just wondering how an untuned ls/vtec should feel like? mods , 11.5:1, p&p h,i,e - 2.5 exh,, crower stage2(springs and retainers), in a 90 crx with a stock obd0 ecu?
Old May 14, 2004 | 06:13 PM
riceball777's Avatar
Default Re: UNTUNED LS/VTEC (gogou99)
my lsvtec is untuned and sine i have hugh *** cams with the stock 4k vtec x over the car off course feels like ****
it feels great until you hit vtec that the car just bogs and has no power
i know i have to get the car tuned and have vtec around 6k
Old May 14, 2004 | 06:30 PM
chris_m's Avatar
* B A N N E D *
Default Re: UNTUNED LS/VTEC (riceball777)
Basic street tuning isnt that hard. Ignition timing and fuel pressure. Read spark plugs and butt dyno. Not the best but it can be done and will help out alot compared to just stock settings.
Old May 15, 2004 | 08:37 AM
Rollo Lawson's Avatar
it gonna run like ****, just the way your car does. don't forget, you also have an ITR intake manifold, rsr header, cam gears, 4950rpm v tec x-over(Crower recommends(sp?) 6000 rpm activation for your cams), no fpr, 255lph fp, 240cc injectors and an uninstalled Hondata. don't expect good numbers and drivabilty with no tune. are you going to finally believe what i told you if somebody on here tells you the same thing? "Honda-Tech, the vast online Honda peformance world of opinions. some people live by it, but most, take dirt naps because of it"
Old May 15, 2004 | 08:48 AM
Karterguy13's Avatar
I have an Ls/vtec:
255lph fuel pump
fpr set at 50psi
cam gears at zero
Timing ?
stock cams
stock head
stock maninold in&out
Itr pistons........
Motor makes power runs alright. bogs a little. I am told by redzone that tuning it will bring it to life.
Old May 15, 2004 | 12:15 PM
gogou99's Avatar
Default Re: (B16C1)
Old May 18, 2004 | 02:07 PM
gogou99's Avatar
anyone else?
Old May 18, 2004 | 02:14 PM
crxirex's Avatar
Default Re: (B16C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16C1 &raquo;</TD></TR><TR><TD CLASS="quote">it gonna run like ****, just the way your car does. don't forget, you also have an ITR intake manifold, rsr header, cam gears, 4950rpm v tec x-over(Crower recommends(sp?) 6000 rpm activation for your cams), no fpr, 255lph fp, 240cc injectors and an uninstalled Hondata. don't expect good numbers and drivabilty with no tune. are you going to finally believe what i told you if somebody on here tells you the same thing? "Honda-Tech, the vast online Honda peformance world of opinions. some people live by it, but most, take dirt naps because of it"</TD></TR></TABLE>
Your very stupid
Old May 18, 2004 | 02:38 PM
TrnsferErr's Avatar
Default Re: UNTUNED LS/VTEC (Karterguy13)
redzones doing my motor
Old May 18, 2004 | 03:17 PM
Default Re: (crxirex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxirex &raquo;</TD></TR><TR><TD CLASS="quote">
Your very stupid </TD></TR></TABLE>
yeah, and your mom's mouth is warm and slippery , BIATCH. WTF are you talking for? i know this dude and his entire set up. his car has performed worse, the more it got modded, for the simple fact that it is an "UNTUNED LS/VTEC" you dumb ****. what are you trying to do, up your post count? the least you could do was elaborate on my stupidity. do me a favour, EAT A DICK, you know, just like...........
Old May 18, 2004 | 05:48 PM
RZProStreet's Avatar
Default Re: (B16C1)
Probably not going to be too great until it is tuned. I wouldn't get on it until you get it on a dyno with a wideband.
Old May 19, 2004 | 04:07 AM
Default Re: (RZProStreet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RZProStreet &raquo;</TD></TR><TR><TD CLASS="quote">Probably not going to be too great until it is tuned. I wouldn't get on it until you get it on a dyno with a wideband.</TD></TR></TABLE>
Thank You.
Old May 19, 2004 | 04:51 AM
T.J.'s Avatar
A good friend of mine has a pretty mild, nice setup. Hes running about the same compression as you . The oly difference is hes running some Skunk 2 stage 2's. The motor just pulls it went 8.3 in the 1/8 on slicks and this was untuned. You should be pretty happy with it.
Old May 19, 2004 | 02:08 PM
specie's Avatar
I had a ls/vtec (itr pistons, ctr cams, itr im/header, mugen pr3 ecu). It ran a tractionless 13.8 @ 103mph in a Crx. It ran great.
Old May 22, 2004 | 10:40 AM
gogou99's Avatar
Default Re: (B16C1)
i just got my car tuned and now it runs great? Hondata does wonders!!! (its true, untuned ls/vtec runs like ****...well atleast my did) thanks
jdragon1974
89
Jun 3, 2013 08:41 AM
siregcivic
67
Mar 13, 2013 03:45 AM
dpine
11
Nov 3, 2003 10:20 AM
1hotintegra
Jul 2, 2003 09:54 PM
initial-d
Nov 25, 2001 09:14 PM
