how do these cams look as far as wear?
Old May 14, 2004 | 05:06 PM
Grip's Avatar
Default how do these cams look as far as wear?
hi im gonna most likely be buying these cams ..they are used but he says they were only used for less then 500 miles..what do u think?..from what ive seen on other used cams they look allright to me....also can you guess what cams they are?
Old May 14, 2004 | 05:16 PM
ArinX's Avatar
Default Re: how do these cams look as far as wear? (Grip)
they look okay, take closer shots of the lobes thats where it counts.
Old May 14, 2004 | 05:38 PM
Grip's Avatar
Default Re: how do these cams look as far as wear? (ArinX)
its gonna be hard to get more pics..he used his brothers digital camera and it took him a few days to be able to borrow it...does anyone think the cams might break or be bent in anyway? is that even possible?..is there a way to improperly store cams?...from the pics they look fine to me for used cams but then again i have no clue what to look for in used cams..they have been stored with the skunk gears on them
Old May 14, 2004 | 08:16 PM
Cory man's Avatar
The only way to check for straightness is by using V-Blocks and a dial indicator. If you are paranoid about them being straight I'd definitely make sure. More money later on out of your pocket if they are bent. HTH
sshh
Oct 16, 2011 05:36 PM
Sl0wEK
Feb 3, 2007 07:01 PM
txracer
Oct 14, 2004 03:10 PM
SamC
Apr 9, 2003 11:25 AM
