I know this has been beaten to death
Im sorry for the redundent post but I want an exact answer before I purchase. I just picked up a 92-5 civic front badge and it fits like a glove. Now for the rear, many people have said that the civic rear fits the integra....wrong. I have aslo heard 00 accord. What is the exact fit? My local honda dealer said once I open the factory sealed container its mine regardless.........Sorry again.
no Silver honda emblem fits the integra, you have to double sided tape it on. What i did was find this clear double sided adhesive, and just stick that bitch on really good. The first time i did it with white adhesive, with this adhesive you cant even tell. Great invention. Break off the tabs of the emblem and adhesive it on.
See, this is the problem, you too are incorrect. The 92-5 civic front H fits almost perfectly, all you have to do is bore the front mount holes out just a tad no bullsh!t taping or guleing.
STRIKE ONE. Anyone else wanna take a swing?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by INTEGRAJAI »</TD></TR><TR><TD CLASS="quote">See, this is the problem, you too are incorrect. The 92-5 civic front H fits almost perfectly, all you have to do is bore the front mount holes out just a tad no bullsh!t taping or guleing.
STRIKE ONE. Anyone else wanna take a swing?</TD></TR></TABLE>
u badass
u badass
I put a 95' civic emblem on the front. Fit perfect
On the back I bought a 95 accord emblem and cut off one of the posts on the back and just used 3M emblem adhesive. Fits like a glove. The only thing you can see is a small part of the original hole when the hatch is up and you are searching for it.
I also used a 95' accord "honda" emblem for the trunk lid. I had to cut both the posts off. and just used the same adhesive.
Good luck
Good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamB18C1 »</TD></TR><TR><TD CLASS="quote">I also used a 95' accord "honda" emblem for the trunk lid. I had to cut both the posts off. and just used the same adhesive.
That emblem wasn't stock, no Honda after 1991 had a HONDA emblem on it, only the H. I used a 90-91 Accord emblem.
As for the rear H, I used the front emblem from a 92-95 Civic, cut the pins off, and used thin strips of 3M emblem tape (like double-sided foam tape, but thinner, and gray colored w/ red backing). I've had it on there for over 2 years now w/o problems.
So the real deal is 92-5 civic front H fits like a golve, just a small amount of reaming of the factory holes and it snaps right in. The 2000 accord and 2000 civic BOTH fit the rear holes exactly with no mods needed. Inheritly, they are both the same emblem.
Problem solved!
jai
Problem solved!
jai
What are you talking about you ******* idiot? I was talking about the rear emblem you moron
Modulo_Black
Honda Civic (2006 - 2015)
Jan 18, 2007 09:11 AM
