gsr out of oil in a month what is the cause?
hello fellow integra owners
i just bought a used 94 gsr with about 145k miles and yesturday my oil light was blinking when i was in the freeway. What happened is that i had no oil left in the car!
I just changed the oil and plugs about a month ago (april 10th)
Other things to keep in mind:
exhaust spits out alot of black crap which gets the back of my car gets dirty fast
I notice that gas mileage is not that great also compared to my 98 gsr and 2k1 itr i had before.
Im thinking a bad cat for the exhaust crap spitting out but im not sure and with the rate of a quart a week of oil i hope its not bad but knowing my luck it is
Can anybody diagnose whats the problem?
If fixable besides rebuilding the engine (not going to do till later at a friends shop)
if its not serious i'm going to go fix the problem now because im low on cash
feedback is appreciated i think it might be serious but i'm not sure so let me know
thanks 10x in advance
From: You can be my wingman anytime...., Las Vegas, US
Are there any oil leaks anywhere?
Sounds also like your car is running rich. How do the plugs look?
I have the exact same problem but mine isnt a gsr...my car barely starts up and the engine light always turns on and gets into "limp-mode"....it always throws code 04 which is "crank position sensor" which in other words is "you need a new distributor"...
it aint cheap either from what i hear. I eat a quart a week and my exhaust is charcoal black...ive been suspecting fried piston rings but i dont have the cash right now for that kind of job...im debating whether i fix the rings or i wait till i got enough cash for a new engine.
from what i see i think there is leaks because of my tegs block vin code is all black because of the oil. I havent had time yet to go to the shop to do compression test because of finals coming up I was just wondering the usual price range for a rebuild?(normal rebuild or built all motor wise)
i haven't asked my friend yet about the price (going to rebuild for all motor) so i'm want to go by a ball park figure.....Currently right now i'm going to install a new radiator because my old one is leaking. i'll try to keep updated with some stuff
as far as it runs it runs perfectly fine and it gets a little better gas mileage after i refilled the oil. plugs look fine but from what i was told when i did my smog test i might have some problem wiht the distrubutor cap. Cause i did barely pass smog (took 4x)
