Melted dipstick!!!
Old May 14, 2004 | 01:32 PM
whackassfawker's Avatar
Default nothing but problems
My ITR has a built motor, Hondata, 18G, Greddy Type 24 FMIC, 3'' exhaust.
I had my car tuned and it put down 315whp at 14psi. A couple days later, I blew my cam seals. I fixed that and I fashioned a catch can to exhaust system to vacuum the crankcase and I'm using an edelbrock 5/8'' check valve. All year so far my oil pan has been unsealable. I put two different gaskets on, still leaks, so I tried another gasket and high heat silicone and it still leaks. So now I bought a new gasket and oil pan from Honda and I'll try that.
What can I do? Also my comp is good across the board and my engine builder did a leak down.
Anyone having problems with melted dipsticks?
Old May 14, 2004 | 05:39 PM
emotionisdead's Avatar
Very Emergency!!
Default Re: nothing but problems (Type R #0008)
turbo=higher temps. could be your dipstick problem. and are your sure its the pan gasket and maybe not the front main seal. my friend has a front main seal leak and i swear to god, it looked like an oil pan. there was no oil below the seal, but it was dripping. sure enough, after three pan gaskets, he replaced the front main and that fixed the problem. oh yeah, make sure you don't overtighten the pan gasket bolts, they only need to be between 6-8 foot lbs.
Old May 15, 2004 | 12:13 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type R #0008 &raquo;</TD></TR><TR><TD CLASS="quote">Anyone having problems with melted dipsticks?</TD></TR></TABLE>
If the block (or engine oil) is getting hot enough to melt the dipstick, rubber seals and gaskets are probably none too happy either.
Old May 15, 2004 | 08:44 AM
machgo5go's Avatar
Default Re: nothing but problems (b19coupe)
It sad to see someone dump so much money and end up with a time bomb.
Sometime things is better to be left alone and just enjoy the ride.
Old May 15, 2004 | 10:38 AM
uNF$@#!'s Avatar
time to get more serious with the cooling....
larger radiator, oil cooler...all will help
Old May 15, 2004 | 01:36 PM
Yes I agree the stock heat exchanger is not suitable for oil cooling duties on this car. Any suggestions on an aftermarket cooler?
Yes I've spent alot, but man is it ever fun to drive.
Old May 15, 2004 | 02:54 PM
Dr Pooface's Avatar
Default Re: (Type R #0008)
Search the archives for oil cooler info, there is alot out there.
Are you absolutley positive that it is the oil pan gasket that is leaking? I'd bet that something else is leaking.
Old May 16, 2004 | 03:10 PM
Ya the new pan and gasket sealed it up nicely. It's going to be fun while it lasts. My max oil temp is 210 which is what it was last year running 6psi untuned. nevertheless my engine builder is going to design a oil cooling system for my using high quality parts because the one's on the market are cheap and expensive at the same time.
Old May 16, 2004 | 05:39 PM
vtec.dc2's Avatar
i melted couple things including compressor fan.. and dispstick don't have as much rubber left - i gotta get some heatshields.. and hood vent is on the way..
Old May 16, 2004 | 06:37 PM
why was this edited?
Old May 16, 2004 | 07:53 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type R #0008 &raquo;</TD></TR><TR><TD CLASS="quote">why was this edited?</TD></TR></TABLE>
It's a conspiracy
I got an IM about one of my posts too. You find out why, let me in on it.
Old May 17, 2004 | 10:02 AM
Damn Republicans!!!
94 IntegraLS
May 7, 2013 11:42 AM
chi_gsr
Jul 3, 2010 05:56 PM
steinar
Jul 19, 2006 12:11 PM
Teglessb18
Oct 21, 2005 03:06 PM
overdose
Apr 27, 2003 02:03 PM
