Base Pressure?
Old May 14, 2004 | 01:18 PM
Acuraman918's Avatar
Default Base Pressure?
I am building too much base pressure. I am burning oil, my car runs great, but it's is causing oil to blow out from under my valve cover. I checked the pcv valve, and everything seems to be flowing just fine. Help me fix my 91 std hatch w/d15. What else would cause this pressure to build up in my crank case?
Old May 14, 2004 | 01:51 PM
C-RICKS's Avatar
Default Re: Base Pressure? (Acuraman918)
I know im not being helpfull but, I have the same problem. Mind you, my car is running great. I was not aware that there is something i can do about it.
I just bought the valve cover gasket and plug-hole gasketimagiggies for the fact that my valve-cover gasket seems to be leaking or something.
Old May 14, 2004 | 01:58 PM
Default Re: Base Pressure? (C-RICKS)
c-ricks....are you smoking too? My problem is I'm burning oil, and blowing smoke
Old May 14, 2004 | 05:38 PM
91civicEX's Avatar
if your rings arent holding compression then the compressed air will go into your crank case. this will cause u to burn oil and build up excess pressure at the same time.
Old May 14, 2004 | 07:14 PM
Default Re: Base Pressure? (91civicLX)
so basically I'm screwed.....time for a DOCH ZC...thanks 91civiclx
TravisBiggie
Jun 24, 2012 04:56 PM
Mr.Chow
27
Jan 6, 2012 06:29 PM
88 EF Hatch
Jun 7, 2009 10:32 PM
92vteclude
Jan 9, 2006 09:42 AM
Acuraman918
May 14, 2004 01:04 PM
