HELP ME Please :(
Old May 14, 2004 | 10:54 AM
nexgen91's Avatar
Default HELP ME Please :(
mpfi swap done. i finaly got my distributor problem solved, i now have spark and the car will crank and run for about 30 seconds on starting fluid, but im not getting any fuel through my injectors. fuel is getting to the fuel rail but not past the injectors, i dont know what the problem is, both wires have a positive charge on them, i got a guy i work with to test for an injector pulse and he said that it was weak. any ideas as to what my problem could be, and how to fix them? thanks
matt
Old May 14, 2004 | 02:25 PM
Perfectionist's Avatar
Default Re: HELP ME Please :( (nexgen91)
Both wires at the injectors will have a positive charge on them. The ECU grounds the circuit to trigger the injectors for a certain duration determined by the base fuel map and various other sensor inputs.
Old May 15, 2004 | 02:21 PM
MSAGRO's Avatar
Default Re: HELP ME Please :( (Perfectionist)
CHECK IF UR INJECTORS ARE CLOGGED
Old May 15, 2004 | 08:53 PM
Donkey85's Avatar
Default Re: HELP ME Please :( (MSAGRO)
maybe a faulty injector resistor box
Lmgrcivic
Sep 25, 2010 04:25 PM
dayl
21
Apr 13, 2010 08:06 PM
