94 clutch and PP on 91
yes im 100% sure it will. however, if you buy a whole clutch kit, the throw out bearing will not be compatible from 89-91 & 92-95.
but i now with absolute certainty that you can use a 92-95 clutch/pressure plate/flywheel on an EF
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude »</TD></TR><TR><TD CLASS="quote">yes im 100% sure it will. however, if you buy a whole clutch kit, the throw out bearing will not be compatible from 89-91 & 92-95.
but i now with absolute certainty that you can use a 92-95 clutch/pressure plate/flywheel on an EF</TD></TR></TABLE>
the clutch disc, pressure plate, and flywheels are all the same 90-up.... the T/O bearing is different....
flipldls
Oct 18, 2009 07:26 PM
highrev1987
Feb 15, 2006 06:57 PM
