running rich after swap
Old May 14, 2004 | 08:43 AM
herde1724's Avatar
Default running rich after swap
just finished my ls swap in a 95 civic ........using a stock pr4 ecu i do have an o2 sensor but i know its bad the car is running really shitty in the bottom end ..........from idle (5-600) to about 2500 the car is very sluggish and if i give any less than half throttle starting off the car stalls out i have the timing at full advance at the distributor
any suggestions would be greatly appreciated
Old May 14, 2004 | 09:58 AM
devnull's Avatar
Default Re: running rich after swap (herde1724)
could be any number of things.
First replace the O2 sensor
then check for vacuum leaks.
Old May 14, 2004 | 10:31 AM
wickedEFguy's Avatar
so the O2 isn't hooked up then or you know that it's bad and that's what your using for the right now?
Set your Timing back to 16 degreess BTDC. Check CAM timing too just to make sure your not off a tooth.
How are the spark plugs that your using?
Old May 14, 2004 | 10:49 AM
Ekasey's Avatar
Default Re: running rich after swap (wickedEFguy)
AGREED above plugs cam timing defintley fix your dizzy timing
Old May 15, 2004 | 02:11 PM
herde1724's Avatar
Default Re: running rich after swap (eLusive ek4)
the plugs were new but i think that with the car running so rich they are already going bad...........as for the cam timing its ok and was gonna put the dizzy back to tdc and see if that helps at all
i ran the codes yesterday
-o2 sensor
-map sensor
-vehicle speed sensor
-water temp sensor.......this one brings up another question i have, there are two extra plugs and neither of which plug into the sensor on the head
i was told that i might have an automatic wiring harness and that would explain the extra plugs i have by the vehicle speed sensor
Ef4doorwagon
Jul 11, 2015 11:08 AM
spens 91 Ef
10
Jan 22, 2010 01:44 PM
mikester1222
12
May 9, 2009 12:09 PM
Jet Black
Nov 25, 2006 06:49 PM
89 CRX SI
Apr 22, 2003 04:21 PM
