quick Q on T1R testpipe
http://www.randdmotorsports.com/detail.cfm?ID=107, That is a 2.5inch in/outlet T-pipe correct?
EDIT: If I get any jdm spec header with 2.5" collector would I need a jdm length testpipe? Also if I go with that setup any usdm catback would bolt on fine?
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lil Corb »</TD></TR><TR><TD CLASS="quote">http://www.randdmotorsports.com/detail.cfm?ID=107, That is a 2.5inch in/outlet T-pipe correct?
thanks</TD></TR></TABLE>
if I understand correctly, you are correct. that is the same setup I am buying so I hope you and I are correct
just realised somethin aint right here.
when i ordered mine im sure the site had the jdm 1 down as 12" and now its got 13". just measured my jdm test pipe i already have and its just under 12".
i remember measurin it at the time to double check before i ordered it.
just hopin their site is wrong. if its jdm test pipe it should fit straight onto jdm header/exhaust. if not im gonna be pissed
can anyone confirm the length of the t1r jdm test pipe they received ?
mine still hasnt arrived so looks like its gone missin in post so gettin refund. may just get em to send another 1 out if its defo 12" but need to know
