450 whp@ 19 psi...finally
Old May 14, 2004 | 05:01 AM
fastludeh22's Avatar
Default 450 whp@ 19 psi...finally
Well after all the hard work, and ALL the mishaps...i just made just over 450@19 psi...
we had to stop there because the spring wont let me go any higher. i jsut ordered a new spring and will be going for 5-600whp...
this is in a street car that still has a/c! 93 prelude
let me tell you THIS BITCH IS FAST!
it made 402 on pump gas, and the 450 run was on 5 gal of 110, 3 gal of 93, so around 104 octane.
setup:
h22a1 block
90 mm 9.xx(9.5, but i grinded out the exhaust valve pockets for my valves)endyne rollerwaves
thick cometic head gasket
the thing is the engine has been decked and milled so much i estimate about 10.5+:1(210 psi on compression test)
eagle rods, w/arp 2000 bolts
king bearings
full rotating assembly balanced
balance shafts disconnected
arp main studs
.5mm oversized ferria valves
duel ferria valve springs
ferria tit. retainers
crower stage 2 turbo intake cam
stock exhaust cam
arp headstuds
skunk2 cam gears
stock intake manifold
hondata intake mani. gasket
p72 hondata s100
walbro 255 hp
160# injectors
stock fuel rail and fpr
msd 6a (digi 6 took a crap on me)
clutch master 10# flywheel
act xtream pp, organic disc.
m2b4 jdm lsd tranny
turbo setup:
garret 60-1, t3 .82 a/r turbine, .70 a/r to4s compressor
drag gen 4 mani(sucks for anything under 15 psi)
tial 40 mm wasgate, on elbow to bored gen mani mount
max rev universal 2.25" intercooler piping
spearco intercooler
hks ssq blowoff
ill add more as i remember
15 psi, pump gas, this isnt the final dyno sheet, we cleaned up the a/f ratio:
19 psi 104 octane:
Modified by fastludeh22 at 2:27 AM 5/16/2004
Modified by fastludeh22 at 10:35 PM 5/27/2004
Old May 14, 2004 | 05:05 AM
RobbieG35's Avatar
12 Years Strong
Default Re: 450 whp@ 19 psi...finally (fastludeh22)
Damn, 400 on pump gas Very good numbers
What are you tuning with by the way?
Modified by HybridHatch88 at 2:19 PM 5/14/2004
Old May 14, 2004 | 05:13 AM
brickonwheels's Avatar
Way to go. When you go back get a vid of you on the dyno!
Old May 14, 2004 | 06:29 AM
kKdARIAN's Avatar
Vice President/CEO
Default Re: (brickonwheels)
one word. WOW
those are GREAT #'s man...
Old May 14, 2004 | 06:38 AM
Rod.'s Avatar
Default Re: (kKdARIAN)
Another 400hp honda released on the streets again...good job
Old May 14, 2004 | 06:47 AM
vaporboy12's Avatar
good numbers have fun with it. let see some track times
Old May 14, 2004 | 08:42 AM
Mikes01GSR's Avatar
Default Re: (vaporboy12)
Great Job man.......Feels great huh???
Old May 14, 2004 | 08:51 AM
G
sh!t happens.
Default Re: (Mikes01GSR)
nice numbers on pump gas. so tell us your setup....
Old May 14, 2004 | 09:06 AM
SiRkid's Avatar
nice!
did you change the turbo?
the 2 curves are quite different
Old May 14, 2004 | 09:46 AM
sky88's Avatar
i wanna make a 450 -500 hp b18c with t03 04 e hybrid turbo,i am not sure what do i need do i need a different block cause my b18c block might be melted right please let me know more info and where to get the so call long block
Old May 14, 2004 | 09:54 AM
TrueNorthStar's Avatar
Default Re: 450 whp@ 19 psi...finally (SiRkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRkid &raquo;</TD></TR><TR><TD CLASS="quote">nice!
the 2 curves are quite different</TD></TR></TABLE>
It looks like the second dyno is quite a bit leaner from 3500-5500 rpms. That could explain it.
Old May 14, 2004 | 09:55 AM
Kangaroo_Boy's Avatar
Default Re: 450 whp@ 19 psi...finally (sky88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sky88 &raquo;</TD></TR><TR><TD CLASS="quote">i wanna make a 450 -500 hp b18c with t03 04 e hybrid turbo,i am not sure what do i need do i need a different block cause my b18c block might be melted right please let me know more info and where to get the so call long block
start your own thread
Great Numbers man, I wanna see a vid of that dyno run
Old May 14, 2004 | 10:11 AM
DD_JonnyLee's Avatar
Default Re: 450 whp@ 19 psi...finally (Kangaroo_Boy)
great numbers, setup??
Old May 14, 2004 | 10:42 AM
Old_Nocturnal's Avatar
Good numbers, I think you have a suprise ahead of you when you turn the boost on up...
Old May 14, 2004 | 11:55 AM
BGPKR's Avatar
Default Re: 450 whp@ 19 psi...finally (Nocturnal)
Old May 14, 2004 | 03:23 PM
Rollo Lawson's Avatar
wicked. those have got to be h22 numbers.
Old May 14, 2004 | 05:06 PM
DLB1994's Avatar
Old May 14, 2004 | 05:10 PM
1316130057's Avatar
Default Re: 450 whp@ 19 psi...finally (DLB1994)
More boost, higher AFR. Of course he'll have more bottom end. Fuel = kills torque.
Old May 14, 2004 | 05:55 PM
Drew Peacock's Avatar
Default Re: 450 whp@ 19 psi...finally (1316130057)
Pic's? setup?? Mad tight props BTW Dam it looks a little lean coming on to boost
Old May 14, 2004 | 07:46 PM
Jdm93civic's Avatar
deng this is in a prelude right...
Old May 14, 2004 | 07:57 PM
posted setup up top
Old May 14, 2004 | 08:03 PM
actually we switched from the a setting to the b setting on the avcr...apperently the solonoid is much more agressive and lets it spool much quicker. i always use b now, just change the amount of boost
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nocturnal &raquo;</TD></TR><TR><TD CLASS="quote">Good numbers, I think you have a suprise ahead of you when you turn the boost on up... </TD></TR></TABLE>
yea after these #'s w/ the mixed matched cams(which is why we think its choking at 7500), my goal went from 5 to 600 whp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbozxi &raquo;</TD></TR><TR><TD CLASS="quote">Pic's? setup?? Mad tight props BTW Dam it looks a little lean coming on to boost </TD></TR></TABLE>
getting a video cam this week. we fixed the a/f, that wasnt the final run, but the #'s were the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdm93civic &raquo;</TD></TR><TR><TD CLASS="quote">deng this is in a prelude right...</TD></TR></TABLE>
yep, fully equipped 4th gen
Old May 14, 2004 | 11:04 PM
SiRkid's Avatar
interesting!
Old May 14, 2004 | 11:57 PM
TURBODC4TEG's Avatar
nice dude
Old May 15, 2004 | 06:33 AM
Mase's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> we fixed the a/f, that wasnt the final run, but the #'s were the same.</TD></TR></TABLE>
yeah u might want to make sure you fixed the AFR down low, you are making 350 ft/lbs at like 14:1 afr. you're lucky the motor didnt blow then
other than that, its killer power
ps the reason you are probably building a lot of boost faster now is because the duty cycle on the high boost setting is most likely higher....this keeps the valve closed longer and does not allow the wastegate to start opening
