questions about new tires
Old May 13, 2004 | 10:08 PM
Chubakon's Avatar
Default questions about new tires
i just got brand new rota rnr today.. n i was wondering wat else do i need for my rims?
do i need to get the (metal mount)*correct me if im wrong on this* thing when i put on the tires?
Old May 13, 2004 | 10:11 PM
Kendall's Avatar
Put the tires on (make sure they are balanced properly), then mount the wheels and you're ready to go.
Old May 13, 2004 | 10:15 PM
CNSK's Avatar
Default Re: questions about new tires (92da-er)
take it to your local tire shop to install it......they should balance it out for you....dont worry about the weights.....they will handle it for you.....
Old May 14, 2004 | 03:13 AM
IntEGNYC's Avatar
I think youre referring to the metal weights that clip on the rims.
when youre at the tire shop, ask them to balance the rims from the inside so you wont have the weights clamped on the outter rim.
Old May 14, 2004 | 03:34 AM
awdpwr's Avatar
Default Re: questions about new tires (IntEGNYC)
i work at the shop. im not a technician, but they always told me with my wheels, that a dynamic balance (sticky weights inside the rim) so there are no weights visible from the outside is not as good as a static balance (weights clip to outside lip) which will give the wheel/tire a true balance. it can be balanced either way, but the static is supposed to be better. some wheels have to be dynamic balanced though.
Old May 14, 2004 | 08:05 AM
nickgmiller04's Avatar
i work in a tire shop and this is what we do.
for any aftermarket wheels, we do not use the metal hammer on weights.
some shops are dumb, you may need to specify that you want a TAPE BALANCE.
also to get a better balance, get a TWO PLANE balance. that has weights on the inside and outside, hence two plane. these are stick on weights that go on the inside of the wheel, not hammered on to the lips.
also, go way before the shop closes. when its time to close, work is rushed.
Old May 14, 2004 | 08:35 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: questions about new tires (awdpwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by awdpwr &raquo;</TD></TR><TR><TD CLASS="quote">i work at the shop. im not a technician, but they always told me with my wheels, that a dynamic balance (sticky weights inside the rim) so there are no weights visible from the outside is not as good as a static balance (weights clip to outside lip) which will give the wheel/tire a true balance. it can be balanced either way, but the static is supposed to be better. some wheels have to be dynamic balanced though. </TD></TR></TABLE>
haha wrong, stick-on weights inside the rim are better than hammer-on weights on the outside.
Actually the best way to balance the wheel/tire is to use both stick-on weights on the inside, and hammer-on weights on the inside edge of the wheel (facing the brakes). That's how I balance my wheels at the shop where my friend works, no vibrations at all (even though all 4 of my GS-R wheels are bent slightly on the inside, you can't tell by looking at them, though), and there are no visible weights on the outside.
Old May 14, 2004 | 08:38 AM
Vinny Chase's Avatar
Default Re: questions about new tires (nickgmiller04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickgmiller04 &raquo;</TD></TR><TR><TD CLASS="quote">i work in a tire shop and this is what we do.
also, go way before the shop closes. when its time to close, work is rushed.</TD></TR></TABLE>
Agree totally, I would go earlier in the day so they have plaenty of time. YEa, the dynamic tape will be best for that type of wheel. Like Patrick said, they also could do on e clip-on weight, and one tape on weight, works good too
Old May 14, 2004 | 08:53 AM
Community Builder
Default Re: questions about new tires (Vince10984)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vince10984 &raquo;</TD></TR><TR><TD CLASS="quote">
Agree totally, I would go earlier in the day so they have plaenty of time. YEa, the dynamic tape will be best for that type of wheel. Like Patrick said, they also could do on e clip-on weight, and one tape on weight, works good too </TD></TR></TABLE>
Well sometimes it takes more than one weight to get it balanced... some of my wheels have like 2 or 3 clip-ons and a bunch of stick-on sections... the balance machine should show exactly where and how much of each weight to install. It will also place the stick-on weights behind the spokes to further hide them from view.
Old May 15, 2004 | 06:46 AM
CNSK's Avatar
Default Re: questions about new tires (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
Well sometimes it takes more than one weight to get it balanced... some of my wheels have like 2 or 3 clip-ons and a bunch of stick-on sections... the balance machine should show exactly where and how much of each weight to install. It will also place the stick-on weights behind the spokes to further hide them from view. </TD></TR></TABLE>
I have my si wheels balanced and the local race shops in here charlotte and they said my SI wheels are perfect with no weights when they balanced it. I have all tires with no weight and im surprised myself even the guy that balanced it, he said he never seen anything like it. No shakes or nothing...im happy with no weights....
kinda wierd but drives good....
EGed up from the seat up
May 30, 2009 03:26 AM
solsi2000
Aug 5, 2008 03:50 PM
p0tential
Mar 29, 2008 08:17 AM
MilanoCpe
Dec 10, 2007 08:23 PM
apm
Oct 17, 2007 01:07 AM
