Check engine light after DC JDM header install
Installed dc sports jdm header and car sound cat. About a week after installation the check engine came on. I havent had a chance to run the code what do you think could be wrong? I tapped in the o2 sensor after the cat. What could be wrong?
You car will waste a lot of gas and all the emission system will be running in open loop mode. Which means none of the sensor's reading will be acknowledge by the ECU. I don't like the idea of running in open loop. Get the problem fix now to avoid any future complicatioins.
Very Emergency!!
i have the same problem with my landspeed cat. it is most likely code number p0420- cataylist under threshold. which means, that the second o2 sensor is not picking up enough change in exhaust gas emission so it throws the code. obdII systems are very, very touchy. good luck.
i noticed ive been using alot of gas. I cant get to the mechanic till monday, will running the car like this harm anything? How can it be fixed? How much $ is a new o2 sensor?
If you can find out what code the MIL is showing, I can tell you what the code stands for. Email me if you need it. Pair72@adelphia.net
Randy
Randy
Mechanic says that its setting off the code for the cat. He says not to worry about it, its just because of its higher flow rate of stock. Does the car go into a safe mode when the check engine light goes on?
thats what I was thinking of. Would I gain any power from switching to obd1 and tuning with hondata? I currently have comptech icebox, dc jdm header, and car sound cat.
streetracerjoey210
Jun 24, 2007 04:48 PM
supapoopa
19
Nov 14, 2005 03:46 PM
GSlowR
Sep 20, 2001 10:27 AM
