jdm-r upgrade
here's pictures my half-done GSR-R
I have a few question that you all might be able to answer.
Where can I find some JDM ITR axles cheap?
Will the USDM ITR hubs fit the JDM ITR knuckle?
If they do, will I need new bearings?
Why are Mugen hard rubber bushings so expensive?
Here's some pictures of my baby all torn apart:
don't judge by the lok on those pics. as honda uses the same pics for different parts sometimes.
you neeed to take yopur old axle at a parts store and compare lenght. if any you should be able to use integra axles with crv outer joints.
Just get some Prelude outter axle hubs. Those should work fine if the hub itself is the same length.
Because they're Mugen.
I used '93 accord axles to make it work.
The passenger side axle fits right in and the driver's side axle needed to be
grafted onto the GSR inner CV joint.
I didn't put the rubber dampers from the stock axles onto the new axles.
Will that affect anything?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trellix78 »</TD></TR><TR><TD CLASS="quote">I used '93 accord axles to make it work.
Yes
</TD></TR></TABLE>Yes
creepy116
Jan 27, 2008 10:49 PM
