What Headers Can i use!?!
Old May 13, 2004 | 07:23 PM
B18Tahtaras's Avatar
Default What Headers Can i use!?!
I have a 92 Integra Gs. My problem is header choice. What headers will work on my car, There are some headers that are supposed to be designed for my car, but im hoping for a single piece design. Wondering if there are headers that work for my car, that were supposed to be designed for a mayeb 3rd Gen Teg?? Preferably 4-1... however lemme know of 4-2-1's that will work as well.
Old May 13, 2004 | 07:35 PM
icemangsr2's Avatar
Default Re: What Headers Can i use!?! (B18Tahtaras)
i dunno if its the same on a gs but my gsr just got its one piece jdm header installed and the crossmember had to be notched to fit it in. and its a TIGHT fit. if i were you id go for a two piece header for ease of installation. u could do it yourself with a two piece. i did one piece cause i got it for cheap from a buddy and a good install price from a shop. comptech, dc sports stainless steel, i hear weapon r makes one though ive never seen it, ANR, hytech, and of course the jdm ones. i do know a guy who got a USDM type R header on his 90 ls that fit very well and gave him a nice boost in power so u might check that out.
Old May 13, 2004 | 09:25 PM
jamessh1's Avatar
Default Re: What Headers Can i use!?! (icemangsr2)
comptech 4-2-1 and edelbrock pro-flo 4-2-1 are recognized as some of the best headers for under $500 USD. If you want a 4-1, the best bang for your buck would be the dc sports JDM 4-1, but apparently it hangs really low and scrapes on lowered cars.
Old May 13, 2004 | 09:34 PM
Kendall's Avatar
Pretty much any B series header will work fine with your application, however some will require slight modifications to the exhaust. It's all a question of how much money you want to spend.
Old May 13, 2004 | 09:35 PM
HondaGuy02's Avatar
Banned
Default Re: What Headers Can i use!?! (jamessh1)
hey jamessh1, what are your thoughts on the header your running?
Old May 13, 2004 | 10:00 PM
jamessh1's Avatar
Default Re: What Headers Can i use!?! (HondaGuy02)
I love it. quality craftmenship and design. The header was dynoed on a gsr in import tuner and put down 13 hp up top and up to 10 lbs of torque on a car with an intake and stock exhaust. edelbrock is slept on for compact performance IMO.
Old May 14, 2004 | 12:35 AM
riceball777's Avatar
i knew that all bseries headers will bolt up to every b seris head. but i found out the hard was why all headers for a 2g are 2 piece.
a second gen integra has a very small engine bay and the crossmember is very close to the engine.
to run a 4into 1 header the crossmember has to be notched to clear the header.
i bought a greddy 4-2-1 header 1 piece for my car and i had to take off the cross member to get the header on
Old May 14, 2004 | 03:16 AM
IntEGNYC's Avatar
if you actually looked around at the headers available, you would have noticed they are model specific.
Unless you or someone you know is good at weld work, stick to your model.
Old May 14, 2004 | 05:13 AM
BulliztyK's Avatar
4-2-1 go that rout, 4-1 is meant 4 more of a top end power
Old May 14, 2004 | 08:39 AM
illi Adik's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jamessh1 &raquo;</TD></TR><TR><TD CLASS="quote">I love it. quality craftmenship and design. The header was dynoed on a gsr in import tuner and put down 13 hp up top and up to 10 lbs of torque on a car with an intake and stock exhaust. edelbrock is slept on for compact performance IMO.</TD></TR></TABLE>
I'd like to see that dyno'd in person.
Old May 14, 2004 | 08:54 AM
xplanetearth420x's Avatar
Default Re: What Headers Can i use!?! (Jackson4Door)
i would like to see him say header instead of headers!!
Old May 15, 2004 | 12:21 AM
Default Re: What Header Can i use!?! (riceball777)
I know that they all bolt up... but my actual questions are more along the lines of where the end drops out to... i dont care how far back it ends... i just need it to be in the same place as far as the height, and how far left/right it drops...
As far as installation goes... that isnt a problem...
Also, would it make things easier if i just went with FAL fans? (comes back to the issue of where the end of the header drops to.)
Old May 15, 2004 | 12:49 AM
redGSRguy's Avatar
Default Re: What Headers Can i use!?! (xplanetearth420x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xplanetearth420x &raquo;</TD></TR><TR><TD CLASS="quote">i would like to see him say header instead of headers!!</TD></TR></TABLE>
He did say header then he asked which headers would work for his car.
Old May 15, 2004 | 05:53 AM
patdemps's Avatar
read more bud. also, you've now got over 1,000 posts, why don't you try working on putting some good information into your posts. I swear your just up for a record in posts or something. Im still waiting for the day you come in with something that actually informs somebody about something
4-2-1 is better for midrange.
4-1 is more suited for drag/top end.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jamessh1 &raquo;</TD></TR><TR><TD CLASS="quote">comptech 4-2-1 and edelbrock pro-flo 4-2-1 are recognized as some of the best headers for under $500 USD. If you want a 4-1, the best bang for your buck would be the dc sports JDM 4-1, but apparently it hangs really low and scrapes on lowered cars.</TD></TR></TABLE>
I prefer the 4-2-1 unless your packing a lot of power all motor. So, I suggest going that route.
Old May 17, 2004 | 09:04 AM
Default Re: What Headers Can i use!?! (patdemps)
alright... you have had your fun... now back to Cars...
i have a 92 GS...
I need to know what will fit on my car other then the ones that are supposidly designed specificly for other vehicles. I am Very familiar with what type of header does what, however, i wanted to know if anyone has put a header on their 92-93 gs that wasn't specifiacally designed for their car. And what modifications were needed to make such a process able to happen
Do all the b-series headers drop do the same point? Because if they do, then i could just modify other things to work with my car...
Old May 17, 2004 | 11:24 AM
arw321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Tahtaras &raquo;</TD></TR><TR><TD CLASS="quote">alright... you have had your fun... now back to Cars...
i have a 92 GS...
Do all the b-series headers drop do the same point? Because if they do, then i could just modify other things to work with my car...</TD></TR></TABLE>
Hasn't your question been answered already?
All b series headers do not drop to the same point. There are so many variances between manufacturer's that it would be next to impossible for anyone on here to tell you exactly how every b series header on the market will fit your car. You SHOULD be able to make any b series header fit your car, but you may run into clearances with your front cross member and possibly your oil pan.
I have a jdm itr 4-1 for my '92 and obviously the crossmember needs to be cut. I also had oil pan clearance issues, and my oil pan had to be "modified" (hammered) slightly to increase clearance between the header and the pan.
HTH.
Adam
DR Honda97
Mar 9, 2006 01:32 PM
typer 00-115
Acura TL, RL & ZDX
10
Jul 28, 2003 03:59 AM
integsr99
Jul 8, 2003 10:30 AM
Scartissue
Oct 14, 2002 05:59 AM
LillDragun
Sep 18, 2002 10:53 AM
