is it bad to have higher lift on exhaust cam than intake cam?
im thinking of putting in sk2 stg1 exhaust and ctr intake cams.
ctr intake specs are: 11.5mm, duration 243 @ 1mm
and sk2 stg 1 exhaust are 10.9 mm, duration 249 @ 1mm
am i better off sticking with both ctr intake n exhaust? or will this setup give me better gains?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing »</TD></TR><TR><TD CLASS="quote">id do it other way around... ctr exhaust and skunk intake... make mo powa that way</TD></TR></TABLE>
how about if you only had 2 choices: go with both intake and exhaust ctr cams or the setup above. which would u go with?
94EJ1Coupe
Mar 5, 2008 08:50 PM
