96 integra o2 sensor. need to put in a air/fuel ratio gauge in my car
I need to put a air/fuel ratio gauge in my car and it needs to be connected to the o2 sensor. I need to know which wire is the sending wire. It has four wires, two black, one white, and one green. Can anyone help?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WeaponR »</TD></TR><TR><TD CLASS="quote">use the white.
I did mines from the ECU cable. Works perfect. Easier to wire up too..
I did mine at the ECU. the white and red wire. Just strip back some covering on the WHITE/RED wire as shown in the picture for a OBD1 GSR (refer to a wiring diagram for your specific year to locate the 02 sensor wire) and splice in the wire from the gauge. Or on the ECU wire, I just tapped into it using a tapper. This way, I avoided actually cutting the wires and it still reads beautifully.
dnt94civic
May 22, 2002 04:54 AM
