brake lights dont work
hey my friend NiceDC2R is about to come to my house and we are going to attempt to fix it one more tiem before the Type R goes back to the body shop
when he got the car back, it had no tail light fuses so we replaced them. all cabin fuses are there and are correct numbers. i also checked if any were burnt out. none were blown. also checked in the engine bay fuse box. nothing.
Do any of you guys have any ideas? also, we just installed a new gauge cluster but that lights up fine. we are running out of ideas, any help would be appreciated!
Deven
Deven
The tails are on the same fuse as the front marker lights, check to see if the fuse is good. If not, check both bulbs in front aswell as rear to see if the filaments are broken or not.
i posted this in his post also, but if that fuse (as mentioned above) keeps getting blown, then replace the JDM city lihgts w. the USDM parking lights... then replace the fuse. THis is what i did, and i have no probs since
dizzyroc88
Jan 26, 2004 07:43 PM
ErikDaGenErik
Jan 26, 2003 10:05 AM
