Exhaust/header question
Ive been searching the archives for a few days now, and, being new to this stuff, I have a couple questions.
1) If I go with a magnaflow cat-back exhaust am I correct in thinking that I can use my cat that came on the car?
2) If im just looking for a header thats better than stock, would a DC sports work, and would it work with my original cat. I'm not looking to blow huge amounts of cash on a header, im mostly looking for something that would help out a bit with everyday driving as opposed to high-rpm racing and not cost a ton. (any brand suggestions?)
I'd really appreciate any help... I just couldnt seem to get an exact answer through reading archived posts.
Thanks
Thanks
you can definately use your stock cat with a DC header (good choice by the way). You should also be able to use the stock cat with the magnaflow, havent had any experience with them but i havent heard of any basic cat-back systems that wouldnt allow you to use a stock cat.
Excellent, thank you
. Im going to go ahead and go with that combo then. Magnaflow says that it will in fact fit.
Which would be better the DC 4-2-1 header, or the 4 - 1?
. Im going to go ahead and go with that combo then. Magnaflow says that it will in fact fit.Which would be better the DC 4-2-1 header, or the 4 - 1?
i heard DC ceramic headers are bad and i heard that u should go with stainless steel
also im thinking that those things should fit with the stock cat as long as u get the ones that were designated for ur specific car
ull hear this a lot on h-t when asking about exhausts and turbos, but go custom. It's cheaper for a deal thats the same if not better in performance, if u pick ur parts right. custom turbos are hard but for exhaust systems, go to http://www.kteller.com get the magnaflow muffler if u want, the piping fit for ur honda, and a resonator or 2 if u want. itll cost a lot less than most name brand cat back exhaust systesms, but whatever u do, good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johneyou »</TD></TR><TR><TD CLASS="quote">i heard DC ceramic headers are bad and i heard that u should go with stainless steel
also im thinking that those things should fit with the stock cat as long as u get the ones that were designated for ur specific car </TD></TR></TABLE>
i dont think that theyre bad but theyve been known to crack, every now and then. I would get a 4-2-1 Stainless DC header
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Djrockz415 »</TD></TR><TR><TD CLASS="quote">ive hit around 130 a couple of times, then came either the fuel cut-off or the governor (98 4cyl)</TD></TR></TABLE>
this post was completely off the subject...
